Old 10-10-2010, 01:45 PM   #11
Lucas13
Drives: 07 Yaris LB
Wow, sorry to hear all of your issues that you have encountered. I think that you perhaps got one of the few lemons.
I have 43k over the 4 years and items that have been dealt with outside of personal upgrades are the following:
1) ABS Sensor per TSB
2) Door pillar insulation per Safety Bulletin
3) Missing Cabin Air Filter from dealership...did a DIY Filtrete
4) Reset ECU done by dealership since my gas mileage was all over the map last winter. One tank I could get 34mpg and the next 17, then the nextx could be 25, then 32. Once the dealer reset my ECU and it relearned the mapping it has done great. Might have been because it sat for a year while I was in Afghanistan without a battery.
5) Stock battery died 100% after 3 years. This must have been due to my stereo system hammering the crap out of it.
Oh yeah, and for some reason I have had to put new oil in it every few thousand miles...what is up with that?
I have no doubt that my Yaris is a lemon or maybe a Tangerine!
I had my A/C drain clogged up too because of the lack of air filter, which for me is totally dishonesty from Toyota of not throwing that filter in they must know what happens without one...
I think you battery went t out like mine and many of the rest, they last about three years, the oil thing doesn’t sound that good with only 43k, you have car checked for leaks or something, an engine may consume some oil if you drive it too hard all the time.
A Daewoo I owned like 4 years ago was supposed to be a piece of crap and turned out much better than my yaris, I put 120K on that thing and all I did was basic maintenance. I’m sure the yaris is the last Toyota I will have.
Lucas13 is offline   Reply With Quote
Consumer Reports Is On Crack!!! doublewam General Yaris / Vitz Discussion 82 05-07-2011 11:03 AM
