![]() ![]() ![]() Drives: 2009 3dr LB Manual Join Date: Mar 2010
The big problem I'm having is getting a beefy spring INSIDE the stock one. Still playing with that. Spring steel isn't the easiest to form, so that's part of the challenge.
Here is one attempt I'm trying today: This is the clip that holds the spring to the bottom hinge side of the arm. As you can see, I bent it closer together, hopefully putting more load on the wiper arm. The weather is suppose to be rainy here the next couple of days, so I should be able to test it out on the highway. I sprayed some black paint on the bare metal from the vise I used. I'll let you know how it feels once I install it later today. |
| DIY - Standing rear wiper for hatchback | sex | DIY / Maintenance / Service | 42 | 10-17-2018 06:32 AM |
| Wiper blades .... | Lafiro | General Yaris / Vitz Discussion | 81 | 02-02-2012 06:54 PM |
| rear wiper arm delete | Giammarco36 | General Yaris / Vitz Discussion | 20 | 05-16-2010 09:03 PM |
| How-To: Liftback Rear Wiper Arm - Full Pivot! | Chris07LB | DIY / Maintenance / Service | 5 | 07-24-2009 03:08 PM |
| Anyone know how the passenger seat detection system works? | rage2 | DIY / Maintenance / Service | 5 | 05-12-2007 07:22 PM |
