resident senior
Weight loss is always good , but try to keep in mind center of gravity . Also by removing the the back seat your car is now more flexible and top heavy . I'm not complaining but just pointing out some safety concerns .
If ya want more weight saving ideas try these . 1. Switch to Braille battery - 20 lbs 2. Remove windshield fluid reservoir -10 lbs 3. Buy wheels that weight less than 11 lbs -15-20 lbs 4. Fill gas tank to halfway mark ( about 5.5 gallons ) -50 lbs 5. Remove front seat -40 lbs ( actually I think it weighs more ) 6. Remove passenger side airbags - 10-20 lbs Another downside to weight removal is that the Yaris has such a large cross section that wind or passing vehicles will greatly affect directional stability .
#2 | |
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris S Sedan 5-Speed Join Date: Oct 2008
Losing the heavy gas seems like the biggest bang for the least sacrifice. People forget how heavy all those gallons of gas weigh. |
#3 | |
Only Happy When it Rains
And removing the passenger side air bag is probably illegal in most states at this point. Oh and if you are interested in Braille batteries, check out Deka. They make braille batteries, and you can get an off name battery that is identical for 1/3 of the price.
Colin Chapman disciple |
resident senior
Let me clarify . The center of gravity I was referring to is in the transverse plane ( up, down ) . All of the mentioned weight removal is below the window line , thus making a top heavy car . A top heavy car with a large cross section on a windy , icy day will not be safe . When considering weight reduction all three planes( coronal , sagital , and transverse) must be taken into consideration .
Also I meant to remove pass. seat . So if you have no pass. seat ...no pass. airbags are needed . I don't know about legality , but I do now that I've never heard of anyone asking to see the airbags when being pulled over . Thanks for the battery tip
![]() ![]() Drives: '09 Yaris Sedan Join Date: Oct 2009
What has all of this weight loss done for the ride quality? Everything you mention, save the light wheels is sprung weight. Rotating parts are really good things to put on a diet. I light weight flywheel would cut the pounds and pep up throttle response. Don't forget to loose the plastic engine cover. I did not weigh it, but I like taking wt off of those front wheels.
doc |
#6 | ||
As for the airbags, in mass if the airbag light is on, the car will not pass inspection. Since the car comes with a passenger airbag, in my state it must be installed or you cannot drive the car on the street. I'd be shocked if it wasn't the same way in most NE states, and the other states that seem to follow cali in lockstep. It is just worthwhile to check out the laws before doing anything like that to make 100% sure you can do it and still drive the car legally. Quote:
resident senior
I say the roof weighs close to 300 lbs ( actual roof , glass, hatch, and panels etc) , but I doubt anyone will cut off their roof so we could find the exact weight
![]() Also by definition any time you remove weight from the center of any object it makes it top heavy . You are correct in thinking the Yaris won't tip over at every turn by losing 111 lbs , but I am correct in saying it won't be a fun drive in a lightened Yaris on a 12 % grade in icy/windy conditions . Not to mention big rigs blowing past you and pushing you around . To answer the ride quality question , the heavier Yaris will give the better ride quality . Go try it out for yourself . Just ride in you Yaris by yourself . Then ride with 1 or 2 adult passengers in the back seat . You will feel the difference fo sho . Here in South Carolina , we don't have car inspections . But if we did and I wanted to remove the pass. airbag , I would be smart enough to remove the indicator bulb as well ![]() Oh about the flywheel , true you can lose a lot of rotating mass , but the trade off is drivability . IMO the stock Yaris flywheel is perfect . With a light weight flywheel you will have to "blip" the throttle to match revs to make gear transitions smooth . With the stock flywheel the weight of it keeps the momentum up making gear changes much smoother .
#8 | |
You are technically right about ride quality. That depends what type of ride quality you are looking for. If you are looking for super cushy, then don't touch anything. I have had 3 people or more in my car 2 times in the 4+ years I have owned it. I enjoy the ride better with all the crap out of it, where I here all the road noise and stuff hitting off the bottom of the car. I find that cool. You're funny. In Mass, they attach the car's computer directly to an inspection computer, so they'd see the code. The thing about rotating mass is spot on. Lightened pulley's and a lighter flywheel make the car harder to drive, and make the idle kinda nutty. For me the trade off is worth it, for others, maybe not.
Our car is down to 1860lbs... The only thing trying to make it tip over the is sticky Goodyear racing slicks. Lighter is better.
![]() ![]() Drives: 07 Yaris Sdn, 97 4Runner Join Date: Jul 2006
What are getting for fuel mileage with all of the weight reduction? Pencil and paper calcuations only, Scan Gauge numbers do not count!
so accuracy doesn't matter? lol.
#12 | |
![]() ![]() ![]() Drives: 2008 5 sp. LB Join Date: Oct 2010
Having to pull a 1,000' grade every day to get home, for me anyway it makes sense and just feels right to not haul any dead weight up with me. I also like not having it with me when going down, it is a win/win. If all I did was level driving I wouldn't be quite so anal about it. I even made a point of getting a small dog, 20 lbs, and keep him on a strict diet. Sure, people tell me all the time "that dog looks like he's starving", but every little bit helps. Making him run uphill helps keep the weight down also. Last edited by Idahotom; 11-13-2010 at 10:12 AM. |
![]() Drives: 08 Sedan & 11 5-door Join Date: Sep 2010
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| Natural Gas Yaris | MadMax | General Yaris / Vitz Discussion | 13 | 06-03-2017 06:10 AM |
| Florida Yaris Meet! 6/23/2007! | Sabretooth | Southeast | 13 | 06-05-2007 06:46 PM |
