Old 11-07-2010, 07:28 PM   #1
MUSKOKA800
MUSKOKA800's Avatar
A bit extreme. Why not just drive a kart if you don't want creature comforts.
Hmmm... remove the steering wheel and clamp a pair of vicegrips onto the shaft. Save more weight and have a tool handy when in need.
Old 11-07-2010, 09:42 PM   #2
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
why drive at all? Why not walk? If you want creature comforts why buy a yaris? Go get a lexus or some other car that actually has them.
Stop being a judgmental moron and realize that everyone else does not want the exact same thing you do.
Colin Chapman disciple
Old 11-08-2010, 01:39 PM   #3
Biff
Super Duper Biff Guy
Biff's Avatar
Drives: from here to there.
right...
Biff is offline   Reply With Quote
Old 11-10-2010, 07:06 PM   #4
Jason@SportsCar
I think you missed my point... Making the car lighter does not make it more tipsy. Make it lighter and you will have less inertia trying to pull it over. Added bonus, better acceleration, brakes quicker, handling improves as well as using less fuel.
Old 11-10-2010, 11:21 PM   #5
docB
Drives: '09 Yaris Sedan
Light is might. A lighter car, all other factors equal, will be quicker, better economy, etc...If one can lighten the vehicle in such a manner that the ratio of weight held up by the springs to the unsprung weight stays constant, then the vehicle will still ride "nice". Just gutting the interior can be good. At the Auto-x my Yaris ran in, I found a point where taken out the weight made the car tougher to drive. Over steer got to be an issue. I think you get a great benefit from lighter parts that spin or reciprocate. Lighter wheels and or tires, fly wheel & clutch, connecting rods. But how deep are your pockets?
doc
docB is offline   Reply With Quote
Old 11-11-2010, 10:21 AM   #6
Idahotom
Drives: 2008 5 sp. LB
"LIGHT IS MIGHT", I like it!
My own take on adding lightness (?), at least on my Yaris, is also not to spend any money, as much as I'd like to carbon fiber everything, lighter wheels etc. Along with that, I'd rather not do anything that'd effect the resale value. While I admire the people who have the deep pockets to REALLY lighten things up, my focus is on not spending any money and making it lighter.
I've noticed just pushing it around in my shop is SO easy, and I've gotten in the habit of, after raising my shop door (converted hangar door and no remote) I just push it outside, then go back in the shop and close the door, then get in and finally start it, thus saving a minute or so of idling. Nothing like a ScanGauge to show you how idling really cuts into your mileage!
After looking at the aftermarket sway bars, I decided not to get one, too heavy! It is zippy enough on the corners as is, I'll just live with it stock. It's still pretty fun to drive! It might be too much fun with front and rear sway bars........
Idahotom is offline   Reply With Quote
Old 11-11-2010, 01:33 PM   #7
HTM Yaris
resident senior
HTM Yaris's Avatar
Drives: 07 Yaris
Tom: for track and autox I take out the rear "junk" so that I can utilize oversteer . In the mountains I leave everything in so that I can utilize understeer . I don't want my tail to be in the opposing lane !
Jason: First of all , I really admire what you have done with the Yaris
But it is really unfair to compare your fully track prepped Yaris with a street driven Yaris . I mean your Yaris looks like it has the correct weight reduction measures ( in all 3 planes ) . I mean really , those Goodyear ( which have extra stiff sidewalls BTW )slicks are enough to keep any vehicle from tipping over Not to mention I feel you have a custom suspension among other things . Try this , put your stock Goodyears on and put your glass back in or up ( not sure if you removed/replaced your glass ) . I feel certain that the stock tires will roll onto the sidewall then the wheels will dig in to the tarmac , then loopedy loop , you will make some body shop happy
Light is might . That is correct to a point . To the point that safety is compromised .
The OP doesn't have a roll cage to stiffen the Yaris up after the reduction in weight . Nor does he have 10.5" slicks with a custom suspension . Nor does he have the driving experience(Yaris) in a panic/performance situation like Jason does .
In no way am I saying that weight reduction shouldn't be done . I'm just trying to point out the potential pitfalls . Another pitfall I forgot to mention is that the Yaris will be more likely to hydroplane with weight reduction . I can't speak for anybody else , but I would not want to be hydroplaning on the downside of a 12% grade Not saying that will happen , but the potential will be increased with weight reduction .
Old 11-11-2010, 02:35 PM   #8
Jason@SportsCar
I would guess you have not drive on a slick... The tires are trying to pull the car over, not stick it to the ground. I have had it on two wheels at least once per race this season - more than once without clipping the curbs, just by grip alone. Street tires will not generate enough traction to pull the car over unless you hit something. As far as sidewall stiffness, that is largely offset by the fact we roll out with 19psi in the slicks, they roll on to the sidewall by design. A great way to pick up MPG is extra tire pressure, a few extra psi can help.
Less weight builds traction, as the tires are not have to work as hard to hold the weight up. More weight on a tire does not make it work more efficiently. At the initial moment of inertia the extra grip will help to prevent wheel spin, but once the car has moved even a fraction of an inch the weight is hurting efficiency.
Worrying about the effect of the trivial amount of weight you could remove and keep the car civilized for the street is a waste of energy.
If you want to use a hydroplaning example keep in mind that the inertia of the heavier car will carry it longer than the lighter car, and it will take longer to recover. You want to prevent hydroplaning, use a better tire.
Manufacturers are going to alternative lightweight materials for a many reasons... It helps fuel economy for one. Another is safety. Look at the numbers, a full size van does not fair better than a lightweight compact when it comes to occupant safety.
No one should be suggesting removal of any safety equipment, or any devices that compromise the structure of the car, but there are things that can be removed without a dangerous downside.
