Old 11-27-2010, 02:07 PM   #1
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
The 1.2 is mm, breaks down to like .045 (which is basically stock). But under boost, i was reading requires a smaller gap. Cali yaris is running .028 at IDK how many psi. I was thinking to set the gap at about .035 or something.
Any thoughts?
Old 11-27-2010, 03:00 PM   #2
.028 gap at 14 psi up.
At what boost level is your meth injecting? I tuned my car up to 14 psi before it needed the meth.
Old 11-27-2010, 03:43 PM   #3
PETERPOOP
PETERPOOP's Avatar
Put in the new spark plugs, set the gap at .035. It actually gave me better AFR. It is now running at about 10-11 AFR during WOT, and 14.7-8 during normal driving.
Here's a new short little clip of doing WOT. Click HD and full screen to see the wideband numbers better..
http://www.youtube.com/watch?v=8kXZRORS9rk
Right now I think I have the meth starting at 2psi. But when I get tuned, I am going to talk to the tuner to see when I should have it start.
Also, my current boost gauge is showing about 4.5 lbs of boost. Not too sure how accurate the gauge is. I thought the zage kit comes at 6-7lbs of boost? Going to be putting in a AEM tru boost digital boost controller in the near future. I'm going to set it at 8 lbs of boost.
Old 11-27-2010, 03:45 PM   #4
Nice!!
I have my meth start at about 6psi. I don't think you need it before that point.
The zage kit comes with 0.5 bar spring which is just a bit over 7psi.
Old 11-27-2010, 05:56 PM   #5
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
.26-.30 gap i guess for when you boost. I guess .35 is ok. Watch for misfires, im surprised you didn't hear it breaking up before when it boosts like little pops everywhere.
Old 11-27-2010, 08:52 PM   #6
Focus_Sh1ft
Focus_Sh1ft's Avatar
I had this problem. It disappeared as soon as I put a manual boost controller in though. Now I'm seeing 8ish during normal driving. The wastegate probably cracks around 5 psi and makes it hard to spool up fully.
How's your BOV situation? I watched the second video and can't really hear it. Kinda glad to see you're having fluttering as well... So far I've fully adjusted and loosened the BOV and it still always flutters.
Old 11-27-2010, 10:11 PM   #7
PETERPOOP
PETERPOOP's Avatar
Slow drive by..
http://www.youtube.com/watch?v=ZG5K3LgsJGw
Re gapped to .030
FocusShift: Good to hear about the boost situation. All I hear is the flutter from the turbo. Can't really hear the BOV. You should post a video of yours......
Old 11-28-2010, 02:38 PM   #8
Focus_Sh1ft
Slow drive by..
Re gapped to .030
Hm, on closer inspection that BOV sound you have is nothing like mine. That's why I didn't really pick up on it at first. I'll try to get a video this week... Tbh I don't know how to capture the sound on an automatic though
Old 12-05-2010, 12:38 PM   #9
PETERPOOP
PETERPOOP's Avatar
Just installed the AEM Tru Boost controller. Putting down about 7.88 lbs of boost. Loving the power. Can't wait to get it retuned. Just waiting for my HKS SSQV 3 BOV to get here.
http://www.youtube.com/watch?v=wHxZFGqow0c
Old 12-05-2010, 02:02 PM   #10
Tamago
Tamago's Avatar
Drives: UZJ100
sounds good, but why spend money on the SSQV?
Old 12-05-2010, 02:23 PM   #11
PETERPOOP
PETERPOOP's Avatar
I found a pretty good deal on the HKS bov and I wanted to try it out. I don't know the quality of the ZAGE bov, and supposedly the HKS bov helps out with performance.
However, unlike most people, I'm not really a fan of the high pitched noise the HKS bov makes.
Old 12-05-2010, 02:42 PM   #12
Tamago
Tamago's Avatar
Drives: UZJ100
there's no way a BOV can improve performance unless the BOV you're currently using is malfunctioning. but a good deal is a good deal, go for it! what will you have to do to modify to make it work?
Old 12-05-2010, 03:09 PM   #13
Focus_Sh1ft
^ We both believe the Zage BOV isn't working correctly and is still allowing compressor surge to happen.
Hey Peter, where did you mount your meth tank?
Old 12-05-2010, 04:08 PM   #14
Tamago
Tamago's Avatar
Drives: UZJ100
so you don't think the bypass valve is opening fully on throttle-lift?
isn't the whole idea of a recirculating valve to help prevent compressor surge?
Old 12-05-2010, 04:21 PM   #15
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
Unplug the line from the bov and hook it up to a boost gauge to make sure you are getting vacuum when you lift off.
rob323 is offline   Reply With Quote
Old 12-05-2010, 07:07 PM   #16
PETERPOOP
PETERPOOP's Avatar
Tamago and rob323: Ok. Here is a picture of the Zage BOV. I was told it was a re-circulating BOV, but i'm pretty sure it's atmospheric.
I'm kinda confused about what you guys are saying about the vacuum line coming off the throttle body. I don't see any vacuum lines on the throttle body; i went to the intake manifold. This is how I have it hooked up...
So that's how I have it hooked up. Am I doing something wrong?
Focus_Shift: Mounted the AEM meth tank inside the car. It's towards the back infront of where the spare tire goes. The backseat isn't there, so it's mounted on a board that was put there to prevent things from sliding forward, where the back seat used to be.
Old 12-06-2010, 04:44 AM   #17
chexmix
Drives: scion xb
damn nice man.. cant wait to see your car in full action
chexmix is offline   Reply With Quote
Old 12-06-2010, 09:11 PM   #18
pimp my yaris
C'est la vie
pimp my yaris's Avatar
Drives: 2009 2 door hatchback
Looks like its hooked up right to me. My BOV vented very easily and I adjusted the spring tension to make it tighter. I have some compressor surge with normal driving. U may notice a problem with dying out if it vents easily. If you recirculate BOV gasses you wont have any problems though.
pimp my yaris is offline   Reply With Quote
Scion XB 1NZ-FE Turbo build xbgod Forced Induction Forum 417 07-24-2011 09:16 PM
XBG's Total Build and Update Thread xbgod Performance Modifications 10 11-18-2010 11:19 PM
Whats needed to turbo charge the yaris? Arkhangel Forced Induction Forum 44 03-02-2009 10:08 PM
