Old 11-16-2010, 08:48 PM   #1
The red wire is not an ideal place to grab switched power. That is the feed to the fuel pump.
Old 11-16-2010, 11:35 PM   #2
M4One
Drives: 2007 Toyota Yaris Hatchback
I installed the fogs using this method without problem until a couple of months ago. Assuming I get them working again the same way, are you suggesting I could end up with problems down the road?
To Focus_Sh1ft, how exactly did you hook the white wire to the battery? Did you wired it like in my diagram, just getting rid of the relay, or through a different method? Ripping everything apart is going to be a last resort for me.
M4One is offline   Reply With Quote
Old 11-17-2010, 07:54 AM   #3
The reason I don't like tapping that circuit for switched power is that if something goes wrong with the switch side of the fog circuit, you will blow the fuse for the fuel pump, which will keep the car from running. The OEM wiring method for the fogs uses an independent fuse for the fogs, so that a failure will be isolated to that circuit and the car will still run.
Old 11-17-2010, 01:02 PM   #4
Focus_Sh1ft
Focus_Sh1ft's Avatar
Drives: 08 Yaris Turbo; 06 tC Turbo
Alright I remember how I did this - lemme clarify.
All I did was splice the end of the red wire to the white wire, then placed it in the ACC position. That's the power wire and it should be fused. That ran to a radioshack switch, then the wires that connect to the fogs run out the other side of the switch. So basically you'll have a +12v feed running from that ACC pinout, to the switch, then to the fogs. This setup will turn the fogs off when the car is turned off as well.
I didn't realize the fuel pump took a feed off that point, so CTScott is right - you really should fuse the fog light wire side as well.
Focus_Sh1ft is offline   Reply With Quote
Taillights, signal lights, parking lights stop working jamal1984 DIY / Maintenance / Service 2 10-13-2010 10:17 AM
Solar powered High Bright LED lights replacing the fog lights alan1828 Canada 10 05-14-2010 12:34 AM
my Projector Fog lights project ezhacker1 Cosmetic Modifications (Exterior/Interior) 3 01-10-2010 05:21 PM
Fog Lights Poll Reeves360 Cosmetic Modifications (Exterior/Interior) 14 12-27-2009 02:00 AM
Sedan Fog Lights, few questions!(where to get) ( make into HID Fog Lights!!!) Lafiro Cosmetic Modifications (Exterior/Interior) 2 06-12-2009 03:56 PM
