#1 | |
![]() ![]() Drives: 2007 Toyota Yaris Hatchback Join Date: May 2006
To Focus_Sh1ft, how exactly did you hook the white wire to the battery? Did you wired it like in my diagram, just getting rid of the relay, or through a different method? Ripping everything apart is going to be a last resort for me. |
#2 | |
Alright I remember how I did this - lemme clarify.
All I did was splice the end of the red wire to the white wire, then placed it in the ACC position. That's the power wire and it should be fused. That ran to a radioshack switch, then the wires that connect to the fogs run out the other side of the switch. So basically you'll have a +12v feed running from that ACC pinout, to the switch, then to the fogs. This setup will turn the fogs off when the car is turned off as well. I didn't realize the fuel pump took a feed off that point, so CTScott is right - you really should fuse the fog light wire side as well. |
| Taillights, signal lights, parking lights stop working | jamal1984 | DIY / Maintenance / Service | 2 | 10-13-2010 10:17 AM |
| Solar powered High Bright LED lights replacing the fog lights | alan1828 | Canada | 10 | 05-14-2010 12:34 AM |
| my Projector Fog lights project | ezhacker1 | Cosmetic Modifications (Exterior/Interior) | 3 | 01-10-2010 05:21 PM |
| Fog Lights Poll | Reeves360 | Cosmetic Modifications (Exterior/Interior) | 14 | 12-27-2009 02:00 AM |
| Sedan Fog Lights, few questions!(where to get) ( make into HID Fog Lights!!!) | Lafiro | Cosmetic Modifications (Exterior/Interior) | 2 | 06-12-2009 03:56 PM |
