Old 11-19-2010, 08:48 PM   #1
p123456789
Drives: 07 lb jeep tj
Originally Posted by silver_echo View Post
you only need to be in the car while it is aligned if you weigh in over 300 pounds... and even then not so much... an alignment is done by adjusting various angles according to MANUFACTURER specifications... there is also a very big safety issue with having the vehicle owner sitting in the car, and to do an alignment, there is a brake pedal depressor and steering wheel holding tool... please do not advise people to insist on sitting in the vehicle, because that is the wrong way for an alignment... /rant
you have to simulate the weight somehow I usually just 150 pounds of sand bags.
p123456789 is offline   Reply With Quote
