Progress so far...
Got the pan back on. Decided to go below the oil line. Installed the turbo manifold, turbo, and downpipe. The oil send/return line, and now working on the water line.
Tightened the bango fitting with this ghetto trick.
Got the manifold and turbo in place without removing the A/C line. We bolted the turbo to the manifold behind the engine, and then lifted it up and bolted it to the block. We didn't bolt it together first and then try and wedge it into place. It was easier to bolt it together while behind the engine.
Quick question. Getting ready to put on the water line to the turbo. I am going to get it from the throttle body coolant lines. Just wondering if it matters which direction it flows into the turbo? Not sure which is "in" and which is "out." Even with the throttle body lines, which is "in" and which is "out." Obviously I can't start up the car to see which way it flows from the engine. If anyone knows, thanks in advance.
