#15 |
From what Ive heard about the new world standard atf fluid is your not supose to mix it with old fluid. It must be 100 pecent removed and replaced with brand new which can only be done with a transmission flush machine. Simply dropping the pan will only remove about 3 quarts. What about the torque converter or the radiator and cooler lines? Ive used a flush machine on many toyotas that you would get only 3quarts out draining the pan but the machine will take out 13 quarts. So your simply diluting. Its like doing a oil change but removing only removing a quart of oil and refilling it back up.
| Should I buy an automatic? | ktoyo | New YARIS Purchase Forum | 40 | 06-23-2010 02:09 PM |
| Used TOYOTA WS Automatic Tranny Fluid analysis : | Hershey | General Yaris / Vitz Discussion | 15 | 03-18-2010 06:29 PM |
| 2008 Yaris AT Fluid change | Rutherfordman | General Yaris / Vitz Discussion | 8 | 07-13-2009 12:45 PM |
| Want opinions automatic vs. manual transmission | anik | New YARIS Purchase Forum | 84 | 07-10-2007 04:25 PM |
| Maintenance - Change Auto Trans Fluid | Linkseal | DIY / Maintenance / Service | 1 | 08-15-2006 10:57 PM |
