Old 11-12-2010, 12:36 AM   #10
severous01
you can always do a pump n fill
loosen the lines to the cooler, get some sort of drainage going. turn car on and put in neutral. run until it starts sputtering and immediately shut off. there should be some sort of fill plug on the side of trans somewhere. fill until it starts coming out. then start engine and put in neutral again and fill agian until it comes out. that will be about 90% fluid. and if you leave it running and it's not pumping fluid....you'll burn up all the clutches and bands in the trans so you really need to be paying attention.
Should I buy an automatic? ktoyo New YARIS Purchase Forum 40 06-23-2010 02:09 PM
Used TOYOTA WS Automatic Tranny Fluid analysis : Hershey General Yaris / Vitz Discussion 15 03-18-2010 06:29 PM
2008 Yaris AT Fluid change Rutherfordman General Yaris / Vitz Discussion 8 07-13-2009 12:45 PM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 04:25 PM
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 10:57 PM
