You must be careful not to over tighten the belt as it could case the altenator, water pump bearings, etc to fail.
#2 | |
![]() Drives: 07 Liftback, Red Join Date: Aug 2006
That's what makes me reluctant to tighten it. Also - I'm not too familiar with the Yaris's layout, but isn't this a serp belt with a spring tensioner? If that's the case, there isn't really anything to "tighten", right? The tensioner applies tension and thats that? Does anybody know off the top of their head what's the service interval for the belt? Thanks. |
#3 | |
I just checked my recommended maintenance schedule. Through to 232,000 km, it does not show any maintenance items regarding this belt. The only mention is an inspection and adjust tension if needed during every other visit.
#4 | |
It's been a long time since I had to do that... can anybody share their technique? Should I be going for the about 1/2-3/4 inch deflection of the belt? Also can anybody share the typical lifetime of the belt in their experience? Or maybe I should just let it go until the belt *really* starts slipping and then just replace it? I really don't want to give the bearings or seals in the alt or water pump an excuse to fail... :) |
#5 | |
![]() ![]() ![]() Drives: 2009 Yaris Onyx Join Date: Dec 2009
| Compilation of Yaris TSBs | eTiMaGo | DIY / Maintenance / Service | 72 | 07-04-2024 10:36 AM |
| DIY - 1.8L 1ZZ-FE TB Connector Chip Swap | Yaris T-Sport | DIY / Maintenance / Service | 332 | 04-03-2022 01:39 AM |
| Cold Idle Speed Question... | cpnnz | DIY / Maintenance / Service | 9 | 11-04-2009 05:31 PM |
| annoyin noise (ticking or rattling) on idle.. | abdallah380 | DIY / Maintenance / Service | 2 | 04-18-2009 05:40 PM |
| Radio noise.. need help | TinyGiant | In Car Entertainment + Electronics (audio / video / alarm) | 13 | 12-06-2008 04:21 PM |
