haha, good point. Except I think Braille uses real carbon?
I could NOT get those pins to fit until I bent the brackets about 10 degrees. I think my hood must have a little more angle than yours.
#2 | |
Hard to see in this image, but the small piece of plastic that separates the front side and the bottom hole has been removed, to allow the pin to enter strait.
Take one apart. We had the "6lb" carbon unit in a past project car, the "carbon" case added 1lb to the 6lb battery. Lots of plastic and clear coat hiding the standard Braille case.
There are not to many parts out there that I would consider real carbon... Almost all of it is one tiny layer over a fiberglass or plastic base. The real stuff is so expensive.
| hood lift? | Qmobile | Cosmetic Modifications (Exterior/Interior) | 19 | 08-14-2010 09:35 PM |
| C-One Replica Hood. Lets Fix this sucker! | TinyGiant | Cosmetic Modifications (Exterior/Interior) | 56 | 11-09-2009 11:31 PM |
| Micro Image Hood Design Contest | cali yaris | Micro Image | 209 | 10-04-2009 02:49 AM |
| Installed hood deflector, in-channel vent visors and hood seal. | IsLNdbOi | Cosmetic Modifications (Exterior/Interior) | 16 | 12-20-2008 08:36 AM |
| Before you buy . . . check that hood! | woof | General Yaris / Vitz Discussion | 4 | 12-02-2006 05:14 PM |
