Old 12-06-2010, 12:38 PM   #1
Eatoman
Eatoman's Avatar
Drives: '07 Yaris 5dr HB
Thanks for the feedback CTScott! I just checked the windshield and there are no chips or scratches to be found anywhere...just this huge crack. I'm starting to wonder if the heat from the vents hitting the cold glass could have caused it to crack. I'm really at a loss. Looking at the placement of the crack, it is directly on top of the dashboard vents that heat the windshield...exact same length as well. Really weird!
Eatoman is offline   Reply With Quote
Old 12-06-2010, 03:18 PM   #2
Laminated automotive glass is designed to handle extremes in temperature and fast temperature transitions. There has to be some type of flaw or damage for it to crack from thermal expansion. If there is no visible chip or scratch (although a scratch would be almost impossible to identify once it becomes a crack), then it very possible that there was a flaw in the glass that eventually failed.
Old 12-07-2010, 12:42 PM   #3
Eatoman
Eatoman's Avatar
Yeah, that's what I figured as well...I found it highly unlikely that a windshield should crack under such circumstances. As for the repair, can I leave it wait for spring? There's no use in changing a windshield in winter with all the flying salt rocks on the highway.
Old 12-07-2010, 01:21 PM   #4
If it's only through one layer, and not in your field of view, then you might as well wait for spring.
Crack on the windshield zyovka General Yaris / Vitz Discussion 9 12-22-2021 10:10 AM
< 1500 miles, broken windshield! :( twowheels General Yaris / Vitz Discussion 18 01-31-2009 09:43 AM
Windshield Treatment Problem Yaris Newbie Wash, Wax, Detailing, Exterior Repairs 20 12-12-2008 01:43 AM
Broken windshield mikeukrainetz General Yaris / Vitz Discussion 17 07-19-2007 07:04 AM
Broken Windshield BlueFlash General Yaris / Vitz Discussion 8 06-02-2007 02:12 PM
