#19 |
feed me knowledge!!!
Drives: 2007 Toyota Yaris 3dr HB. Join Date: Feb 2007
I am looking at buying one and rebuilding the top end. forged titanium rods, forged aluminum pistons, bore it out to 76mm (1.6L), and new head gasket to change the compression to 8.5:1. This way It will be able to handle forced induction reliably and have a little bit more displacement.
#20 |
Lurker supreme!
Sounds like an awesome project!!! But I'm not sure if its quite the same engine. I remember hearing something about 2 belts, whereas we have just one...? There are more qualified people than me to answer this.
2006 Red Blitzed RS 5-door |
#21 |
$1000usd for rods, pistons, head gasket, and all hardware.
#22 |
and $650 for a use engine. (if I can find one that works.)
#23 |
No power steering belt on the Yaris. Its electric... boogie woogie woogie.
#24 | |
#25 |
I was just stating the reason for the extra pulley on the Scions... I don't know shit about engine swaps!
If you need a steak grilled or a computer built, call me though.
#26 |
#27 | |
Lurker supreme!
Ya. Woah... thats pretty damn cheap! If you've actually found such a deal, lemme in on it, ok!!
![]() Quote:
#28 |
Cow-munching nerds unite!
#29 |
#17
Toyota 16V DOHC 2000-04 Engine Code Stock Bore Includes: Engine Kit #/Price 1NZFE 75mm Complete Gasket Set Performance MLS Head Gasket ROSS/Wiseco Forged Pistons (75, 75.5, 76mm) and (8.5, 9.0, 9.5, 10.0 comp ratio) Plasma Moly Rings TOGA HP Main Bearings TOGA HP Rod Bearings Thrust Washers EKTO41MPX $969 Call to Order: (603) 378-0090 |
#30 |
there is an upcharge for materials cost on titanium.
#31 |
Lurker supreme!
oooooooooooooooooooooooooooooooooh!!!
#32 |
![]() Drives: Flint Mica 2007 Yaris S M.T. Join Date: Dec 2006
Making a 2zz-ge fit into a Yaris is no easy task, you will need:
1.) An extreme amount of talent and time or... 2.) A TON of money and a quality shop. Once you figure out the wiring, engine mounts, CV/lug conversion, and all the firewall modification to make it fit its a matter of making it pass emissions. For those living in a non-testing county this is easy. If you want to receive a BAR sticker for 49 state emission legality the engine/ecu must have the following: *Be at least the same year or newer than the chassis (thus limiting your 2zz-ge choices) *Maintain all factory emission equipment from that powertrain (no hacking cats/stand-alones/etc) Its true, you could drum up a nasty supercharger system and piggyback computer and tweak it to run clean enough to pass most emission tests (no check engine lights). For the price of a 2zz-ge swap you could either rebuild the engine with titanium components and reinforce the block or just keep throwing in stock 1nz's at $300 + labor per shot. This way you could also revert it back to stock if you had to sell it w/o trying to explain your Franken-Yaris to a confused buyer. If your dedicated enough to swap the 2zz I would just cherish every minute with the car and figure a way to register it in the boonies. Its a much easier way for most people to get new license tabs. PS: The 1zz-fe and the 2zz-ge are equal in difficulty to swap while the only advantage the 1zz has is its price and availability. Performance per buck is nowhere near the 2zz. |
#33 |
why go through the trouble to switch engines, the day that there is a sick turbo that comes out for our car your gonna regret waisting all that money bcuz once there is a sick turbo kit out you can build off of that turbo kit and try to get maximum power out of that, if not just sell your car and invest the money you were gonna on a engine swap on a new or used suby or in that class of car..i plan on having the yaris only for about 3-4 years bcuz i want a way faster car bcuz im to young and dont go the flow but soon ill be making bucks to pay off my car and buy a new one
#34 | |
#35 | |
Sure though, sell the Yaris and get a used WRX. Then you will realize that every gear grinds and half the teeth off your pinion shaft reside on the bottom of the trans. Believe me, an ex suby guy...the only performance Suby with a decent trans to hit the USA is the STI. There is always someone faster out there. Buy a car you like and be happy with it. Otherwise the one day you sell the Yaris to get a Suby you will run into someone with a fully built Supra, Corvette, 911 GT2, etc and you will feel like its all been a wasted effort. Not trying to knock the dream...just trying to keep it all in perspective. We have all been there once. |
#36 |
Modification Condoner.
Drives: 2007 Black Sand Liftback Join Date: Jan 2007
K20Z1 FTW.
| Yaris Engine | Christopher | General Yaris / Vitz Discussion | 1 | 01-17-2007 03:14 AM |
| engine modify Yaris D-4D | uraz | Performance Modifications | 10 | 04-30-2006 11:53 AM |
