Originally Posted by Midnight Drifter
Well, not for nothing, but down the road I also plan on doing an a-pillar gauge and that'll probably set off an airbag light when the original is removed... so it's better to know now how to just remove the bulbs. :P
Removing the A-Pillar cover won't make the SRS unhappy (unless you disconnect the side curtain squib and turn the ignition on with it disconnected).
Here's a thread about how to change the color of the LEDs in the cluster that shows the details of removing and taking apart the cluster. All of the indicators are LEDs, so removing them means desoldering.
http://www.yarisworld.com/forums/sho...r+color+solder
