Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 05-16-2012, 04:11 AM   #1
syntax
syntax's Avatar
Originally Posted by kaemong View Post
salamat po sa reply...sige subukan ko yang suggestion nio, naaborido kasi ako dun sa fault indicator...
eh saan kaya nila ginamit ung pinabili nila sa akin na ACdelco X66a? hindi ba carborator yong parts sa pagitan ng Engine Filter, kasi dun nila inispray. wala kasi ako alam sa makina.
ung ACdelco X66a card and choke cleaner ito, iniispray ito sa loob ng TB
( throttle body), habang nag rrev ang makina.. ito ay remedyo para sa taas baba ng rpm ( rpm hunting ang tawag dito ng toyota). ung fault indicator sabi nga ni duke pwede ireset kapag tinanggal mo negative cable sa battery then kabit ulit after 10 minutes, pero kapag andun pa rin, baka kailangan icheck ang MAF at ung mismong TB.
Old 05-08-2012, 03:20 AM   #2
rickyml
rickyml's Avatar
Drives: Yaris 2008
kens car
baka may gusto sa inyong sumama...
ipapameet ko sa kuya ko para sa order kong cobra alarm at bosch horn
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter)
rickyml is offline   Reply With Quote
Old 05-08-2012, 06:43 AM   #3
levanz2007
levanz2007's Avatar
Drives: 2007 toyota avanza G m/t
^^^ kay Ken Scar^^^ hehehe i-add nio siya sa facebook niyo....
levanz2007 is offline   Reply With Quote
Old 05-08-2012, 06:51 AM   #4
rickyml
rickyml's Avatar
Drives: Yaris 2008
na-add na sir.
Old 05-12-2012, 06:29 AM   #5
rickyml
rickyml's Avatar
Drives: Yaris 2008
How do you check your car battery status/life?
yuasa is not available in the market but excide is available with 18months life span... any advice/comment?
Old 05-16-2012, 04:00 AM   #6
syntax
syntax's Avatar
insan wala ba indicator light un battery? ung nasa ibabaw ng battery..
Old 05-16-2012, 09:40 AM   #7
rickyml
rickyml's Avatar
Drives: Yaris 2008
alam ko lang diba white, black, green... pero di ko maindicate.
Old 05-16-2012, 10:35 AM   #8
syntax
syntax's Avatar
ang alam ko green is ok, hehe ung ibang color di ko pa alam, mamaya iccheck ko insan, sinisilip un sa ibaba ng battery
Old 05-23-2012, 08:54 AM   #9
rickyml
rickyml's Avatar
Drives: Yaris 2008
question.
ano ba yung sumisirit na tunog when u just started ur engine tapos pag-onn mo ng AC... yung parang naiipit. ang alam ko doon diba sa belt yon. bumili na ako ng betl dressing pero bumabalik din every 5days.
Old 05-23-2012, 08:59 AM   #10
syntax
syntax's Avatar
question.
insan hindi effective ang belt dressing, kailangan lang i torque to specs ulit ang belt or higpitan....
Old 05-24-2012, 05:52 PM   #11
rickyml
rickyml's Avatar
Drives: Yaris 2008
yun ang tanong... paano ba higpitan yon?
Old 05-26-2012, 02:40 AM   #12
syntax
syntax's Avatar
try mo dito insan, luwagan mo ung mga bolts then hilahin mo palapit sayo then kapag hinihila higpitan mo naman ung mga bolts,
Old 05-26-2012, 04:24 AM   #13
xtremist
xtremist's Avatar
Drives: yaris Y 2010 A.K.A. "sky"
ngek...sinong may torque wrench? yung mga nagkakabit ng belt sa mga shop ang style nila yung "NG" kahit sa redcap ganun sila maghigpit....
Ciao !!!
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
xtremist is offline   Reply With Quote
Old 05-26-2012, 04:20 AM   #14
xtremist
xtremist's Avatar
question.
ganyan din prob ko...pero ang isang palaisipan sa akin ay may sumisirit na tunog kapag nakapark na ako galing sa byahe tapos on ang A/C ko, akala ko sa belt, pinalitan ko na pero ganun padin.
Ciao !!!
Old 05-26-2012, 04:22 AM   #15
rickyml
rickyml's Avatar
Drives: Yaris 2008
sa akin naman nawawala kapag mga 20secs na nagana ang AC.
Old 10-13-2012, 05:35 PM   #16
mcjeri
Drives: Toyota Yaris Sedan 2011
Bagong kayaris po from Jeddah.. Ask ko lang po kung ano na yung nangyari dun sa problema ni extremist na sumisirit n tunong. ganyan din po yata din ang sa akin, pag naka park at naka on ang a/c dining mo ang tunog sa loob ng kotse at nawawala yung tunog pag tumitigil and a/c.
mcjeri is offline   Reply With Quote
Old 10-16-2012, 11:00 AM   #17
xtremist
xtremist's Avatar
pre, welcome sa yarisworld....regarding dun sa problem kong tumutunog, sa ngayon d ko na nadidinig. una kong tanong syo, nagpalit ka ba ng muffler mo? ginalaw mo ba yung exhaust pipe mo? kc parang nawala yung tunog nung akin nung ibinalik ko ng stock ung muffler ko with orig piping, mukhang may singaw lang dun sa gasket/bushing nung exhaust pipe. kaya lang, wala akong mabiling orig na gasket kaya pansamantala nilagyan ng d kasukan na gasket, ang naririnig kong sagitsit na minsan e kapag umaandar ako, paminsan minsan lang naman so ang hinala ko talaga dun sa gasket.
Ciao !!!
Old 10-17-2012, 02:16 AM   #18
mcjeri
Salamat po sa pag welcome!!! Regarding dun sa mga tanong mo hindi pa ako nagpalit ng muffler at nag galaw sa exhaust pipe ko. Maraming beses ko na kasing sinukan dalhin at ipa check sa Toyota ang naririnig kong tunong pero di pa rin nila magawa... Yung tunog nga pala ay naririnig ko lang kapag naka on ang a/c ko lalo na pag naka park.. Pero maraming salamat pa rin sa imformation na ibinibigay nyo sa aming mga bagong kayaris... Keep it up....
