Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 05-26-2012, 11:07 AM   #1
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
Originally Posted by syntax View Post
no problem pre' attend ka ng 1st friday meet natin para makilala mo ang buong grupo, sa june 1st na un wala pa lang venue kung saan,
tol sa June 1 sa taler daw mga 10 am daw, but since nasira ang gate ng talyer e not sure pa din ito waiting pa sa advice ni ka bong...
ang first friday natin ay inusod ng June 14 same estraha marami kasing okasyon kaya may sasagot ng estraha, as usual potluck ito at cgurado disposables ang sayo
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Old 05-27-2012, 01:17 AM   #2
syntax
syntax's Avatar
Drives: Yaris Sedan 2010 "shadow"
salamat sa advice pre' antay na lang natin ang advise ni kuya bong about sa talyer,
nausod ba ng june 14? same straha pa rin ba? disposables? hehehehhe alam mo na?
syntax is offline   Reply With Quote
Old 05-26-2012, 06:46 AM   #3
rickyml
rickyml's Avatar
Drives: Yaris 2008
insan... baka may AC insulation ka pa dyan. manghihingi ulit ako. hehehe
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter)
rickyml is offline   Reply With Quote
Old 05-26-2012, 06:52 AM   #4
syntax
syntax's Avatar
naku insan wala na tagal na kasi ang DIY na yan, check ko kina glenn at ung sa mga hindi pa nag DIY ng A/C insulation.
Old 05-27-2012, 04:29 PM   #5
charlieXX
Corporate Slave
charlieXX's Avatar
Drives: 2010 Yaris YX aka "Cutie"
yung gasgas ko ang dapat ninyong makita para ma shock kayo daming mababait dito sa lugar ko inggit kasi umaandar at palibhasa maganda at malinis palagi yaris natin kaya bad trip mahuli ko lang may ipapakain ako sa pato
Si Vis Pacem Parabellum
CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to.
Keep your ride rockin and rollin
charlieXX is offline   Reply With Quote
Old 06-03-2012, 12:12 PM   #6
rickyml
rickyml's Avatar
Drives: Yaris 2008
May nkpagpaMVPI na ba sa inyo na nkamuffler na?
Old 06-04-2012, 01:09 AM   #7
rickyml
rickyml's Avatar
Drives: Yaris 2008
siguro nman pwede kahit naka-muffler ka, mahalaga kasya yung ipinapasok na tube/pipe para i-test. correct me if i'm wrong
Old 06-04-2012, 02:16 AM   #8
syntax
syntax's Avatar
insan' si duke ata nung nagpa MVPI naka aftermarket muffler na, hindi naman daw sinita, si EJ naman may ibang experience, ung tube na pinapasok ata ay para sa emission test,
Old 06-04-2012, 03:19 AM   #9
rickyml
rickyml's Avatar
Drives: Yaris 2008
so, that means... pwede. hehehe. kc kaka-expire lang ng MVPI ko last year. need to renew para sa pagtransfer ng car sa name ko.
Old 06-04-2012, 04:37 AM   #10
duke_afterdeath
positive yan d2 sa riyadh tol, ako at si Harold naka pagpa MVPI na with aftermarket muuffler at ok naman
Old 06-04-2012, 05:25 AM   #11
rickyml
rickyml's Avatar
Drives: Yaris 2008
shoukran! balik na naman mga stocks ko. hehehe
Old 06-03-2012, 12:35 PM   #12
templar101
Drives: 2012
mga kabayan panu gnagawa ang ac insulation. ano mga kailangan. tnx
Life is a journey!
Enjoy the ride!
templar101 is offline   Reply With Quote
Old 06-05-2012, 04:24 AM   #13
syntax
syntax's Avatar
pre' check mo ung thread natin na DIY compilations or ang thread na ito
http://www.yarisworld.com/forums/showthread.php?t=28274
Old 06-04-2012, 08:53 AM   #14
BoyMalambing
BoyMalambing's Avatar
Drives: Toyota Echo 2005
Magandang balita yan.... so tuloy ko na ung aftermarket adjustable muffler ko... tago ko na lang stock muffler ko para sure din....
This is my 1st first car in Saudi Arabia
BoyMalambing is offline   Reply With Quote
Old 06-05-2012, 02:19 AM   #15
rickyml
rickyml's Avatar
Drives: Yaris 2008
yung sa akin... baka ibalik ko na sa stock... naiingayan na si misis eh... para daw syang nakasakay sa sarao bip bip
Old 06-05-2012, 03:40 AM   #16
zsazsa zaturnnah
zsazsa zaturnnah's Avatar
the same sentiments kaya hindi ako naglagay ng ganyan sa yaris ko ... ang ingay nung daewoo lanos ko noon pag naka recta na sa highway ... hikab ako ng hikab para lang hindi magbara ang tenga ko sa ingay!
zsazsa zaturnnah is offline   Reply With Quote
Old 06-05-2012, 03:44 AM   #17
BoyMalambing
Ako naman panalo yan sa akin para di ako makatulog habang nagdadrive hehehehe
Old 06-05-2012, 08:45 AM   #18
rickyml
rickyml's Avatar
Drives: Yaris 2008
kung malapit ka lang... ipagbibili ko na lang muffler ko sayo w/ silencer na yon. hehehe
