Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Middle East
Old 05-26-2012, 05:45 AM   #2539
d"A"
d"A"'s Avatar
Drives: Yaris Y 2012
Ito po yung scratch... Sana maremedyuhan pa....
d"A" is offline   Reply With Quote
Old 05-26-2012, 05:56 AM   #2540
syntax
syntax's Avatar
sir, normal na yan sa saudi... hehehehe.. pero mukhang kaya pa ng touch up paint then kapag natuyo na ung paint, i wax mo then buff, try mo two coats ng wax na paste ha.. hindi ung spray type lang... make sure na at least 2 hours nakababad ung wax pero not in direct sunlight.. mukhang maliit lang naman ung scratch..... kaya pa yan...
Old 05-26-2012, 06:01 AM   #2541
d"A"
d"A"'s Avatar
Thanks po sa reply... Kakairita lng po makita kasi...sa gabi ko po tirahin para malamig lamig at after ma wash... Salamat po ulit.... Sana po eh makasali ako sa talyer session... Need ko A/C insulation he he he he...
Old 05-26-2012, 06:23 AM   #2542
syntax
syntax's Avatar
no problem pre' attend ka ng 1st friday meet natin para makilala mo ang buong grupo, sa june 1st na un wala pa lang venue kung saan,
Old 05-26-2012, 06:46 AM   #2543
rickyml
rickyml's Avatar
Drives: Yaris 2008
insan... baka may AC insulation ka pa dyan. manghihingi ulit ako. hehehe
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Eastern Region Chapter)
rickyml is offline   Reply With Quote
Old 05-26-2012, 06:52 AM   #2544
syntax
syntax's Avatar
naku insan wala na tagal na kasi ang DIY na yan, check ko kina glenn at ung sa mga hindi pa nag DIY ng A/C insulation.
Old 05-26-2012, 11:07 AM   #2545
duke_afterdeath
duke_afterdeath's Avatar
Drives: 2008 Yaris Sedan
tol sa June 1 sa taler daw mga 10 am daw, but since nasira ang gate ng talyer e not sure pa din ito waiting pa sa advice ni ka bong...
ang first friday natin ay inusod ng June 14 same estraha marami kasing okasyon kaya may sasagot ng estraha, as usual potluck ito at cgurado disposables ang sayo
Yaris X: The Largest Most Organized Pinoy Yaris Owners Group In The Middle East (Central Region Chapter)
Disclaimer: Not Connected to Toyota A.Lathif Jameel ME In Any Way
If everything seems under control, you`re just not going fast enough...
duke_afterdeath is offline   Reply With Quote
Old 05-27-2012, 01:17 AM   #2546
syntax
syntax's Avatar
salamat sa advice pre' antay na lang natin ang advise ni kuya bong about sa talyer,
nausod ba ng june 14? same straha pa rin ba? disposables? hehehehhe alam mo na?
Old 05-27-2012, 11:28 AM   #2547
duke_afterdeath
yup same estraha tol,, don't 4get the dispo damihan mo kc mahaba ang oras, umpisa tayo 6pm ng thursday at matatapos ng 6pm din ng friday, isang araw na ito hindi na half day hahaha...
Old 05-27-2012, 04:29 PM   #2548
charlieXX
Corporate Slave
charlieXX's Avatar
Drives: 2010 Yaris YX aka "Cutie"
yung gasgas ko ang dapat ninyong makita para ma shock kayo daming mababait dito sa lugar ko inggit kasi umaandar at palibhasa maganda at malinis palagi yaris natin kaya bad trip mahuli ko lang may ipapakain ako sa pato
Si Vis Pacem Parabellum
CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to.
Keep your ride rockin and rollin
charlieXX is offline   Reply With Quote
Old 06-03-2012, 12:12 PM   #2549
rickyml
rickyml's Avatar
Drives: Yaris 2008
May nkpagpaMVPI na ba sa inyo na nkamuffler na?
Old 06-03-2012, 12:35 PM   #2550
templar101
Drives: 2012
mga kabayan panu gnagawa ang ac insulation. ano mga kailangan. tnx
Life is a journey!
Enjoy the ride!
templar101 is offline   Reply With Quote
Old 06-04-2012, 01:09 AM   #2551
rickyml
rickyml's Avatar
Drives: Yaris 2008
siguro nman pwede kahit naka-muffler ka, mahalaga kasya yung ipinapasok na tube/pipe para i-test. correct me if i'm wrong
Old 06-04-2012, 02:16 AM   #2552
syntax
syntax's Avatar
insan' si duke ata nung nagpa MVPI naka aftermarket muffler na, hindi naman daw sinita, si EJ naman may ibang experience, ung tube na pinapasok ata ay para sa emission test,
Old 06-04-2012, 03:19 AM   #2553
rickyml
rickyml's Avatar
Drives: Yaris 2008
so, that means... pwede. hehehe. kc kaka-expire lang ng MVPI ko last year. need to renew para sa pagtransfer ng car sa name ko.
Old 06-04-2012, 04:37 AM   #2554
duke_afterdeath
positive yan d2 sa riyadh tol, ako at si Harold naka pagpa MVPI na with aftermarket muuffler at ok naman
Old 06-04-2012, 05:25 AM   #2555
rickyml
rickyml's Avatar
Drives: Yaris 2008
shoukran! balik na naman mga stocks ko. hehehe
Old 06-04-2012, 08:53 AM   #2556
BoyMalambing
BoyMalambing's Avatar
Drives: Toyota Echo 2005
Magandang balita yan.... so tuloy ko na ung aftermarket adjustable muffler ko... tago ko na lang stock muffler ko para sure din....
This is my 1st first car in Saudi Arabia
BoyMalambing is offline   Reply With Quote
