FS: OEM Cruise Control Stalk with Wire and Screws
I have a couple of brand new, OEM cruise control stalks with the cruise control wire that connects the stalk to the clock spring and the two mounting screws. If you're in the CT area, I can give you a hand with the installation.
I also have the pins necessary for installing it on a 2008 and older Liftback or a 2009 and older Sedan: http://www.yarisworld.com/forums/showthread.php?t=31763 Cruise Stalk.jpg
please pm me with ur paypal and when i get home from work tonight i will send u funds.
Banned NOT!
Drives: Car Join Date: Jan 2010
scott, my 2010 sedan will no be available? :( cant fit? :(
It will fit a 2010 Sedan.
Magnum23 installed cruise control on his 2009 Sedan. His Puerto Rico spec Yaris had the wiring at the steering column, but did not have the wire from the ECM to the column, so he had to run that wire to make it work on his. Look at this page of this thread for more info: http://www.yarisworld.com/forums/sho...to+rico&page=3
![]() ![]() Drives: Blue,Sedan Join Date: Sep 2010
That's correct, Eckodg contact me if you need any help
Top Notch!
Pins?
I thought 08 yaris is screwed for CC?
Blah, Blah, Blah, Blah
Check out this thread for all of the details, but in a nutshell all 06 to present US and Canadian Yaris ECMs have had the functionality built it. http://www.yarisworld.com/forums/sho...ght=faq+cruise
![]() ![]() Drives: yaris Join Date: Jan 2010
scott do you have a diy kit that i can get as i have a 2008 yaris sedan and just want the easy way....let me know...thanks
#9 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris 3dr LB (Bayou Blue) Join Date: Oct 2008
Is this DIY fairly easy or difficult?
-Jen <3 ![]() Quote:
It's fairly easy. On your 08 it would require adding the pin to the ECM connector, running the wire through the passenger side firewall grommet and under the dash, across to the steering column, adding the two pins to the connector on the column, removing the airbag, drilling the 1" hole for the stalk in the lower steering wheel cover, mounting the stalk, and moving the horn wire from the existing connector to the stalk's connector.
No one has written up a soup to nuts DIY on doing an OEM stalk on an 07 or older, but all of the pieces mentioned above are detailed in the DIYs linked to in this thread: http://www.yarisworld.com/forums/showthread.php?t=25515
![]() Drives: stripped sedan Join Date: Dec 2010
With all of Scott's posts and fast shipping, I will have CC before my payment books arrive. He is a real stand-up guy, thanks.
![]() Drives: 2004 Corolla Join Date: Jan 2011
Still available?
I have an auto 2010 3dr. From what I can tell, all i need is the stalk, the y-cable, and screws. |
#13 | |
That is correct (and I do still have a couple).
![]() ![]() ![]() ![]() ![]() Drives: it is kinda stock Join Date: Oct 2010
so these would just be plug and play basically?
Correct. On 09+ Liftbacks and 2010+ Sedans all of the wiring is in place.
hmm this is tempting and im in ny ill pm if need be
![]() Drives: 2008 Red LB Join Date: Nov 2008
Hey scott, want one. Let me know. I need the full set up as I have a 2008 hatch. I can paypal you the money, just need to know where to send it.
![]() Drives: Toyota Yaris Join Date: Jun 2025
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| Can we do this? (aka The DIY Cruise Control Thread) | mrbond | DIY / Maintenance / Service | 502 | 07-22-2017 02:57 PM |
| This is pretty frikken stupid - Yaris '07 LB auto cruise control | firemachine69 | DIY / Maintenance / Service | 10 | 07-20-2010 08:09 AM |
