Old 12-27-2010, 10:58 PM   #1
dwoodpub
Drives: 2005 Yaris Hatchback
Thanks
Thanks for the reponse. My Yaris is an automatic, if that makes a big difference.
[QUOTE=yaris2010RS;543730]there was another thread on this issue; every time the member would depress the clutch fully it would try to crank again
i dont recall if that issue was ever resolved but it was said to remove the relay and bang it on something hard (or replace it) as something inside is sticking
on the other hand i am assuming u mean the starter motor continues to crank the engine even after the engine starts, like said above, the yaris has an "auto" start feature, all u have to do is move from the "on" position to "start" position with the key for a second and the starter will continue to crank untill the engine catches.[/QUO
dwoodpub is offline   Reply With Quote
DIY - Headlights off with the Ignition Switch CTScott DIY / Maintenance / Service 46 11-03-2018 08:42 PM
2005 Rear Undercarriage Pic Needed? gapi Cosmetic Modifications (Exterior/Interior) 0 09-21-2010 05:52 PM
FS: Motec M4 Standalone ECU w/ Ignition Expander Biggie™ Items for Sale by private party 6 10-20-2009 02:36 PM
Moving the Ignition To The Left? MadMax Cosmetic Modifications (Exterior/Interior) 4 10-02-2009 11:57 PM
