#1 | |
Yaris is regular negative double pulse, not 5 wire, the difference would have been using SPDT relays to make it work, not different actuators. Based on the symptoms you described, what is the most likely cause is that they tapped in to arm/disarm wires instead of using the lock/unlock wires. When using a DMM, the arm/disarm wires would have displayed the same characteristics as the lock/unlock wires. In the yaris, you can pulse the arm/disarm and it will lock/unlock. The wires need to be moved to the lock/unlock, and need to be programmed for double pulse. Save money on stuff you don't need, and take it back to have them do it properly. In the event that they don't have access to techdocs or directechs, then let me know, and I will send you the proper wiring diagram when I get to work on Monday.
Toyota Moving Forward ...even when you don't want it to. Special thanks to Cali Yaris, 1NZYaris1 and lilredrocket
#2 | |
![]() ![]() Drives: 2011 Base Sedan Join Date: Oct 2010
if so the alarm has this programmable feature edti heres what the manual says Double Unlock Pulse: (On / •Off) - Configures system to change the single unlock output pulse into a double pulse. Some vehicles require a double pulse to unlock the doors; when needed this feature saves the expense of optional parts. the feature is currently off, do I turn it on?
http://db.tt/QIWZ2E2 Click to signup for dropbox, and get bonous space, I do too! Last edited by gabriel2012; 01-01-2011 at 12:06 AM. |
| Door Lock Switch System | sex | DIY / Maintenance / Service | 2 | 11-02-2009 12:02 PM |
| Can I add my OWN power window/mirror ? | Chickon | Cosmetic Modifications (Exterior/Interior) | 12 | 07-04-2009 12:28 AM |
| Power Enterprise Super Charger Kit Round 2 $3100 | Power Enterprise Evan | Forced Induction Forum | 312 | 03-26-2009 06:48 PM |
| add power mirrors | mikenacarato | DIY / Maintenance / Service | 1 | 01-22-2009 04:06 PM |
