Old 01-22-2009, 09:29 AM   #1
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
add power mirrors
what would one have to do to add power mirrors? im pretty sure the wiring is all there so i can plug up a switch, BUT are the mirrors in the car now ready for power as well or do i need new mirrors?
Old 01-22-2009, 04:06 PM   #2
Shroomster
'07 to '12:2 wipers to 1?
Shroomster's Avatar
need new mirrors.... the motor is in the mirror assembly itself....LIST:
- new mirrors (just swap the colored inserts to the enw ones be careful the clips are all facing each other, you'll see what I mean by that)
- fuse for under hood panel---or in car panel probably a 15a
- check to see if the wiring harness is there, if not you'll need a wiring kit that runs from the fuse panel to both door harnesses
- master door switch/ driver side panel switch assembly (dependent on where it goes)
- harness for this ^^^ might be included with the wiring harness for the driver side not mirror, not sure....
Can I add my OWN power window/mirror ? Chickon Cosmetic Modifications (Exterior/Interior) 12 07-04-2009 12:28 AM
Power folding mirrors mi_j In Car Entertainment + Electronics (audio / video / alarm) 2 03-23-2009 09:46 PM
Possible to only install the power mirrors? WolfWings DIY / Maintenance / Service 0 09-25-2007 11:04 PM
WTB: JDM Power folding mirrors BlazingBlue08HatchBack Items for Sale by private party 0 04-10-2007 05:31 PM
