Old 01-11-2011, 08:59 AM   #1
chilly79
Drives: 09, 3dr, LB, Carmine Red
Even with the cable broke you should be able to lock the doors with your key.
I just put one of these kits on my car and can see how it will eventually brake. The issue is because the lock cable is solid so the bending weakens it and then it brakes. I was able to get mine so it does not bend so much though. When I looked at the two cables I saw the one for the door lever is a stranded cable which is stronger and would work better. It looks like they both are the same size. If you go to a junk yard get the cable for the lever and use it instead of the lock cable. Be sure it will fit first though. I know it looks the same on the door handle side but not sure about where it meets up with the rest of the door.
I plan to try an rig something up with Brake wire for mountain bikes if mine brake. Too much trouble to try and do it while it still works though. It looks like it would work and would only cost about $20. The head of a brake cable is a cylinder instead of a sphere but the size looks about right to fit.
chilly79 is offline   Reply With Quote
Broke 50 MPG STC Fuel Economy Forum 71 12-13-2010 01:04 PM
HELP! Interior Light Color Change Seedo broke chilly79 DIY / Maintenance / Service 9 10-25-2010 09:20 AM
Broke spade connector on end of ground wire... IsLNdbOi DIY / Maintenance / Service 7 02-06-2010 03:26 AM
I broke my fan switch... HELP *MAD DOG* DIY / Maintenance / Service 10 07-23-2009 09:47 AM
Water broke in car. Washing Car seats? Help! Yaribeth Wash, Wax, Detailing, Exterior Repairs 30 04-14-2009 09:05 PM
