Old 02-04-2010, 11:56 PM   #1
IsLNdbOi
IsLNdbOi's Avatar
Broke spade connector on end of ground wire...
So I was trying to remove the ground wire from the battery today to install a new head unit.
The nut was very, very tight and in the process of trying to remove it, the spade connector of the ground wire broke off w/ the nut and bolt still attached to it.
Am I SOL or is this something a car repair place can fix easily?
Old 02-05-2010, 04:47 AM   #2
1NZYaris1
1NZYaris1's Avatar
buy an aftermarket earthing kit .
Old 02-05-2010, 05:31 AM   #3
IsLNdbOi
IsLNdbOi's Avatar
It's hard to describe the wire I'm talking about. The ground wire I'm talking about is the stock one that's connected to the negative terminal of the battery. It's pretty short and it looks like part of it is coming from somewhere behind the battery and there's a thinner wire that branches out and goes the opposite way of the main wire. The spade connector on the end of the main wire that attaches to the negative terminal of the battery is what broke off. That thinner wire that branches out is connected to a flat piece of metal attached to the spade connector. There's a nut and bolt that keeps this thinner wire attached to that flat piece of metal and if I could get that nut and bolt off, I could just attach that to the negative terminal as well and be done with it.
It's kind of impossible to get that nut and bolt off now though since that part broke off the flat metal piece and I can't hold it in place to screw the nut off (it's very, very tight).
All of what I described is difficult to understand w/o pics., but it's too dark out now to take some.
Old 02-05-2010, 05:51 AM   #4
IsLNdbOi
IsLNdbOi's Avatar
Here's a picture:
The red line is where it broke off, so the part that clamps on to the terminal is gone. The part circled in yellow is the nut that I cannot get off. Since the original clamp is gone, I can't secure that end of the ground wire to anything to keep it still / in place to get that nut off.
I went to Autozone and got a new clamp. The clamp has a part that extends out that has a built in screw (circled in green).
If I can get that nut and bolt off (circled in yellow on the first picture), I can simply slide that end of the ground wire into the new clamp I got at Autozone.
Old 02-05-2010, 08:15 AM   #5
I personally would have removed the ground cable from the battery terminal, and given that terminal a good cleaning while at it. Lots of corrosion there and it certainly needs a cleaning.
Can you pry open the crimping tabs on the nut piece still attached to the cable? Remove it, and crimp the new clamp assembly back in place.
Old 02-05-2010, 02:17 PM   #6
IsLNdbOi
IsLNdbOi's Avatar
The picture above isn't of my car, I just found it in another thread and it showed what I was talking about so I "borrowed" it.
What are these crimping tabs you speak of? I don't see them, unless they were attached to the part that broke off.
All I have now at the end of that ground wire is the piece that nut and bolt are attached to. If I can remove that nut and bolt, I can insert the new clamp into that hole the nut and bolt were in.
Old 02-06-2010, 03:10 AM   #7
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
Mix baking soda with water and soak it. It will neutralize the acid and remove the corrosion. This will make easier to remove the bolt.
Old 02-06-2010, 03:26 AM   #8
IsLNdbOi
IsLNdbOi's Avatar
I finally got it out. I went to some Toyota dealerships first, but all of them wanted to charge $55 and up just to remove the bolt and repair the end of the ground cable.
So I took my car to a local body shop and they were able to remove the bolt easily. All I had to pay was $10 for the mechanic's lunch.
DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) CTScott DIY / Maintenance / Service 221 07-16-2025 01:20 AM
Word Association Black Yaris Off-topic / Other Cars / Everything else Discussions 7373 10-04-2011 10:43 PM
Installed the Tanabe Strut bar but had to remove my ground wire kit.. vacantj Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 10-01-2007 01:56 PM
JDM GROUND WIRE VOLTAGE STABILIZER TOYOTA YARIS jamal1984 Performance Modifications 17 03-26-2007 01:01 PM
Harman Kardon Drive + Play for IPOD sroberts In Car Entertainment + Electronics (audio / video / alarm) 5 07-01-2006 01:05 PM
