Old 01-20-2011, 10:48 PM   #1
Hershey
Only 2 quarts needed . Make sure car is level as possbile , then pour into filler hole until it runs out and comes to a slow drip .Then replace the plug . Can get a bit messy , but well worth it . When finished take it for a good spin and work through all the gears , including reverse . You'll notice a big difference not long after . The clunk into reverse disappeared as well . May want to take the car for a drive before the gear oil change so it flows out better when warm / hot ( metals suspended in oil ) . Good Luck .
Old 01-21-2011, 12:54 AM   #2
yaris2010RS
yaris2010RS's Avatar
hershey, u love oil threads.....
as for only needing 2 quarts, i would personally buy a little more, if u luck out and dont touch it then u can return it, but if u need it at least its there, better to have too much then not enough. especially if thats the only car u have to get to the store to get more oil if needed.....
auto transmission fluid change bribri DIY / Maintenance / Service 4 01-01-2012 10:39 AM
Royal Purple Transmission Fluid caveatipse DIY / Maintenance / Service 14 01-09-2010 03:02 PM
Transmission vent hose leaking fluid Kavi General Yaris / Vitz Discussion 2 06-15-2009 07:14 PM
wrong transmission fluid? supmet DIY / Maintenance / Service 14 02-19-2009 04:01 PM
Transmission Fluid caveatipse DIY / Maintenance / Service 2 09-15-2007 06:03 PM
