Old 01-22-2011, 11:20 PM   #1
p123456789
Drives: 07 lb jeep tj
The only benefit synthetic oil has is to improve cold weather starting. We're talking 0 degrees F here. It will not make your engine last any longer or run any better. Its more expensive too although not as much as it used to be. And yes, with the ammount of miles on your car, its very possible you will get oil leaks because its thinner and flows more easily. Not that they would be serious but some people make a living here scaring people about oil leaks. I used to rebuild engines for a living so I know what Im talking about. Change your oil regularly with conventional oil and the engine will outlast the rest of the car easily.
Good Luck!
10w30 in synthetic is the same weight as dino in 10w30. It has been proven time and time again that synthetic doesn't break down as fast as dino. I'm not saying your enigne will last longer on synthetic but you can extend your intervals which is nice if you drive alot. All my vehicles have synthetic and none of them leak a drop of oil.
p123456789 is offline   Reply With Quote
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 04:22 AM
Is it safe to change from synthetic oil to regular oil hero General Yaris / Vitz Discussion 18 02-21-2010 10:51 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
