![]() ![]() ![]() ![]() ![]() Drives: . Join Date: Feb 2007
I would say "do it!" The Yaris is no slouch (it will out-0-to-60 a 2.5 litre Jetta) and if you want to compare it to the cars of your (OK, "my") youth, it will out-everything an MGB. More power, less weight, more comfort, better suspension and handling, and has a lot of usable luggage/carrying space. Plus, it comes with a better stereo than the old 8-track....
#2 | |
![]() ![]() ![]() Drives: 2010 Carmine Red hatchback Join Date: Mar 2009
Of course, my Sprite is modified, so comparing a stock one (or a stock MGB) to a Yaris will have much different results. If I had to choose between the two I would keep the Bugeye and suffer when it rains or snows (but then I'm sort of a glutton for punishment). Oh yeah.....you don't need a stereo in an old roadster. The sounds the engine makes are music enough.
#3 | |
Engine and transmission: BMC A-Series, 4-cylinder, ohv, in-line. 948cc, 62.9 x 76.2mm, 43bhp at 5200rpm; 52lb ft at 3300rpm. 4-speed gearbox; Chassis: Independent front suspension, coil springs and wishbones. Rack-and-pinion steering. Rear suspension by cantilever quarter-elliptic leaf springs and radius-arms. Front and rear drum brakes. 5.20-13in tyres. Dimensions: Wheelbase 6ft 8in; front track 3ft 9.75in; rear track 3ft 8.75in; length 11ft 5.25in; width 4ft 5in; height 4ft 1.75in. Unladen weight (approx) 1328lb. Typical Performance: Maximum speed 86mph; 0-60mph 20.5sec; standing ¼-mile 21.8sec; overall fuel consumption 34mpg. Fate: Dropped in favour of restyled MkII model in 1961. At 43hp with a weight (dry) of 1328. that's 72.5 hp per ton. Yaris at 106hp/2300 lbs - 103 hp/ton. "Warmed over?" I'd say your thermometer was under-reading a bit. And Yes, I'd keep the Frog-eye, too...
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| Natural Gas Yaris | MadMax | General Yaris / Vitz Discussion | 13 | 06-03-2017 06:10 AM |
| Florida Yaris Meet! 6/23/2007! | Sabretooth | Southeast | 13 | 06-05-2007 06:46 PM |
