you nailed it.
![]() ![]() Drives: 2zz MR-2 Spyder Join Date: Nov 2010
Camber and tire wear....
Just a follow up on tire wear comments....
If you're treating the car the way you should (burning through the twisties as often as possible) a few - degrees up front and -1.5 in the rear won't wear the tires out unevenly. If all you do is drive in a straight line, don't bother with a performance alignment, and you should probably consider a vehicle that's more fun in a straight line. |
| question on Rear Hub Spacers | mastaofdisasta | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 02-02-2010 09:54 AM |
| Adjusting rear camber?? | PHXDEMON | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 63 | 10-23-2009 12:11 PM |
| New Product: Penguin Garage Rear Camber Shims! | Penguin Garage | Penguin Garage | 11 | 10-22-2009 10:20 PM |
| Penguin Garage Rear Hub Spacers!! | Penguin Garage | Sponsors Classifieds Area | 92 | 09-02-2009 06:16 PM |
| Handling changes from rear hub spacers and minor concern. | YarisSedan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 07-10-2009 08:07 PM |
