Old 02-20-2011, 10:14 PM   #1
swidd
Drives: Yaris HB
Yeah, quick fix is go to www.sonicelectronix.com and buy this or this or something similar; any 6.5" will fit. Hopefully someone else will recommend a speaker/brand more suitable for non-amplified yaris applications.
Rip out the door panel and install a new speaker.
You can have the dealer install the same crappy speaker and just have the same problem again when you turn the volume up again, or fix it with decent speakers and be done with it. The OEM speaker is a thin paper speaker with a quarter-size "magnet", and will never produce good sound.
Also, if its a rattle sound etc, ebay some "B-Quiet" and go berserk with some sound dampening. Or if its a speaker bracket that's vibrating, try squeezing something behind it so it won't be so loose.
Also... see if you can get a pro-rated refund on your platinum warranty. Its most likely a $1000 rip-off. Apply the refund to your loan or take it and buy speakers =) If you're in NE PA I can help you install.
Need some experienced advice about speakers Nexus1155 In Car Entertainment + Electronics (audio / video / alarm) 0 06-28-2010 11:18 AM
Speakers for 2009 4DR LB AutoXBot In Car Entertainment + Electronics (audio / video / alarm) 5 05-03-2010 12:49 AM
Is worth it to replace only front and rear speakers? tealio In Car Entertainment + Electronics (audio / video / alarm) 35 04-16-2010 10:11 PM
went to a car audio shop...they suggest 8" speakers severous01 In Car Entertainment + Electronics (audio / video / alarm) 11 03-24-2010 10:15 PM
Fitting rear speakers in Toyota Yaris nish1979 In Car Entertainment + Electronics (audio / video / alarm) 4 03-23-2009 12:56 AM
