#37 |
Little Eggy
Drives: Toyota Yaris Liftback 3DR 2009 Join Date: Apr 2010
oh, hmm =/. Well my friend helped me about having the green wire tapped into the factory pin leading to the fog light Light in the guage cluster and it works.. What's the bad thing about that? i mean everything works and i do have the "kit relay" still part of the whole thing. The only disadvantage he told me is that when i switch the high's on, it doesn't disable it and he said that won't pass inspection. =/
#38 |
![]() ![]() Drives: Toyota Yaris (2010) Join Date: Feb 2010
I want to install the fog lights using the parts that come with the kit!(trough the firewall)
To which wires do i connect the ACC and the Battery power wires using the splice connectors that came with the kit?
#39 |
![]() Drives: Yaris HB Join Date: Aug 2009
Thanks a lot, I received my kit today. I hope to install them this week.
#40 |
How can I install the foglights without the factory way. I mean, how can I install them in a way I can turn them on without turning the Headlights on, just turning it on with the switch that comes with the kit and the relay, etc.
#41 |
Is there any way of installing the kit without putting it to work with the stock wiring?
#42 |
Ok, I finally installed them and put them to work!
#43 |
![]() ![]() Drives: new vitz Join Date: Apr 2010
am unable to seee these picture fully, plz help. each pic is loading only at
half |
#44 |
![]() ![]() Drives: 07 Yaris Join Date: Dec 2009
Okay installed mine only one problem... the indicator light for the switch stays on even with the car off?? is this a problem/ will it kill my battery?
#45 |
To make the light stay off you have to modify the circuit within the switch. If the switch has LEDs for the lights then there won't be an issue with battery drain.
#46 |
And how would i modify the circuit?
#47 |
#48 |
![]() Drives: 2007 Join Date: Nov 2006
My fog lights work perfect, but the fog indicator light on the panel is not turning on...
any ideas? |
#49 |
![]() ![]() Drives: 2008 Yaris 3dr Hatchback Join Date: Oct 2010
I have mine working now, first switch went bad.
Still wondering though if I get a factory stalk with foglight option, how will the fogs operate? Only with the headlights on? The way they work now I can turn them on anytime, with the car running or not. |
#50 |
If you switch to an OEM stalk they will just work with the low beams on, unless you cut the wire going to pin 4 of the stalk and tie the stalk end of it to ground (which will allow you to turn the fogs on at any time).
#51 |
![]() Drives: Vios Join Date: Feb 2010
Mine working fine and I hook the relay trigger to my low beam(LH) pin8 on D4. My fog light can only be turned on if I turn on the head light, which is what I want. The problem now is if I switch to high beam the fog light wont work. Is there any signal I can tap dimmer light? From the manual it stated pin9 but high beam also share same pin9.
#52 | |
![]() If you hook it to pin 13 they will turn on with the lows and highs, and will still turn off when the headlight switch is off.
#53 |
Thanks for the tips CTScott. I think I have tried all the pins and it didn't worked. I will try again this weekend.
#54 | |
| Fog light install | 07yaris_fe | Cosmetic Modifications (Exterior/Interior) | 10 | 07-20-2010 01:18 PM |
| Looking for the Toyota Fog Light install | RocknRollRon | DIY / Maintenance / Service | 33 | 06-13-2010 06:46 PM |
| DIY:Day time running light Disabled with stock fog light remain function | summergxz | DIY / Maintenance / Service | 12 | 09-26-2007 10:42 AM |
| Before I start calling around: fog light install prices | St_G | Cosmetic Modifications (Exterior/Interior) | 4 | 03-17-2007 09:45 AM |
| Finally installed oem ebay fog light for hatchback | Adriaan | General Yaris / Vitz Discussion | 6 | 12-27-2006 04:24 PM |
