Old 02-24-2011, 06:13 AM   #1
Yaross
Yaross's Avatar
Drives: 2006 Yaris HB 5DR
sirs, just a stupid question...
if we really wanted CC in our yaris, but our ECM was not equipped:
1. can we swapped our ECM with those that have CC already programmed in it? --or --
2. can we use our existing ecm but with some modifications?
our yaris is drive-by-wire, so there must be some other way to do it...
Yaross is offline   Reply With Quote
Old 02-24-2011, 07:35 AM   #2
Only the ECM for the 1.5L engine has the built in cruise control, so if your Yaris has the 1.5, then you could swap in a USDM ECM.
The other option is to use one of the aftermarket cruise control systems. There is one system from Europe for Toyotas and I believe that the Rostra system will work with non-US Yaris.
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 12:59 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 11:12 PM
