#1 | |
Progressive springs are H&R, also a good choice, but a milder drop than you have now.
ヤリスワールド
Drives: 2008 HB Join Date: May 2010
I run prokits with tokico reds...unless you just want a look... to low can be a problem as you have found out. I have a slammed excort gt and it's useless except for a quick run to a close store.
![]() Drives: 2007 Yaris Hatch Join Date: Dec 2010
Per our conversation, I did use the word "bouncy"
It does not "bounce" in a sense that it is out of control, or "just going up and down" because the strut can't control the spring. I had a Nissan where the strut could not contol the spring. The tires "cupped" in about 2500 miles. This is not the same sensation. The better term is "it follows the road" and the roads are not smooth. The car sticks like glue. When traveling down the highway at night, you can see the headlights raise and lower as it shines on signs in the distance. It seems to be more of a problem on concrete roads, rather than asphalt. Read the following, you responded http://www.yarisworld.com/forums/sho...t=king+sagging |
| Another rear spring option! Honda Fit springs!! | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 29 | 10-23-2009 05:02 PM |
| Hyperco 5.5" single pigtail rear spring test | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 33 | 06-15-2009 10:11 AM |
| Track Suspension | id3379 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 85 | 06-11-2009 05:59 PM |
| Spring Advice. | *MAD DOG* | Performance Modifications | 7 | 03-01-2009 10:14 AM |
| shock/sturt and spring advice | cdmyaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 08-07-2007 11:18 PM |
