Old 02-19-2007, 11:59 PM   #1
Nimble
Modification Condoner.
Drives: 2007 Black Sand Liftback
"fatty 205's"? a 225/50 will fit nicely on a 15X7m I only think there are 2 of us running this size, but it is a hugh improvement and no rubbing problems
With the Tanabe springs I have, no way will 225's fit without a perfect offset, and even then, with any added weight, my car would rub. The car is pretty slammed with these springs. Besides, no 100hp fwd car needs 225's, I like my gas mileage. 205's, or maybe even 195's for me. The tire compound is more important to me.
Tanabe DF, Debadged, stripped, Black emblems
Nimble is offline   Reply With Quote
Old 02-20-2007, 12:12 AM   #2
Black Yaris
der Zeck
Black Yaris's Avatar
no rubbing when it is lowered, here is proof http://www.yarisworld.com/forums/fun...?do=view&id=44
The advantages of running the 225's a re cornering, shorter braking distance, grab and go on hard accel... no spinin tires. And for the off set +38 will do ya with no rubbing problems, even if it is lowered +3 fat friends... also my gas milage has not been effected by running 225's... exactly what compound are you looking for?
Old 02-20-2007, 12:28 AM   #3
Nimble
I want summer, max dry traction, because I have the stockers for winter. But saying that the 225's reduce wheelspin on a Yaris is comical, sorry man. In order to spin the tires, you need to be dropping the clutch like a idiot. Trust me, the brakes will fade FAR before a good sticky 195 tire will. I think you're buying into the "bigger is better" hype too much. BTW, all things equal, a 195 15 tire will weight at least 3 lbs less than a 225 15 tire, that will affect the acceleration and gas mileage negatively.
No need to debate it with me, nothing you say will have me putting full size German car tires on my little Jap hatch.
Old 02-20-2007, 10:49 AM   #4
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Givr it some time Nimble, it will settle a bit lower... mine is a little over 2" lower front and rear...
Nimble, do you belong to e46fanatics?
Tucks nothing like my 330 though.
Old 02-20-2007, 06:31 PM   #5
Nimble
Dang that's low! hehe
No, I was always a E36/E30 owner, so I'm a member of bimmerforums, bmwplanet, and dtmpower.
Not usually a fan of chrome wheels, but they look nice on your E46.
tanabe nf210 vs. TRD lowering springs?? static808 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 37 01-23-2012 11:00 PM
TANABE SPRINGS C2AUTOSPL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 11-20-2008 07:38 PM
Tanabe DF & Strutbar install mcdaddy DIY / Maintenance / Service 18 05-03-2007 09:57 PM
HOLEY COW 674.75 to install TRD lowering springs dbaxter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 08-09-2006 12:40 PM
TANABE DF210 SPRINGS AVAILABLE!!! C2AUTOSPL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 08-05-2006 12:28 AM
