#19 |
That might help, but based on what others are saying above, it sounds like the trunk really needs something to be added to assist the torsion bars.
#20 |
![]() ![]() Drives: toyota yaris sedan Join Date: Sep 2010
So what do you propose i do then ?
#21 |
For all of those that have the same problem that i had with my trunk i think i found a solution to it but it's a 2 man job
I recently purchase a new set of torsion bar to replace the ones that i had on and when i change them the results were even worse that the ones that was on already so here's what i did You're going to need to lap the torsion bar twice around each other instead of the one that u usually do when you replace it , Then you're going to have to try n put it back in in place that's the hard part and there you're going to need someone to hold the trunk up for you while you fight with the torsion bar At first it's going to seem impossible but it's possible i'm going to post some pictures so that you can see what i'm talking about |
| Remote trunk opener | Dec24th | Cosmetic Modifications (Exterior/Interior) | 16 | 01-29-2016 09:18 PM |
| Sedan trunk question | brg88tx | General Yaris / Vitz Discussion | 15 | 07-08-2010 02:30 PM |
| Adding Power Trunk Release Ideas...Need Help | Jrilla | DIY / Maintenance / Service | 12 | 08-23-2009 02:38 PM |
| Trunk carpeted and rear seat belts removed (lots of pictures) | m911gt | Cosmetic Modifications (Exterior/Interior) | 24 | 05-24-2009 04:38 PM |
| yaris sedan remote trunk relase question pls help soon | fantabulousbaby | New YARIS Purchase Forum | 4 | 08-05-2006 01:26 AM |
