![]() Drives: Toyota Vios Join Date: Oct 2008
JUN Cams for 1NZ-FE
They look like they have a LOT more duration.
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2010
Did it use the stock cam followers?
How does it run? |
it is plug and play.
dur 66 valve lift 9.5mm |
^ before and after dyno would be good to see.
By the way guys, these cams are over $800... EACH.
Please Note Result varies from car to car, engine to engine.
the car the Power BHP the Torque Nm Thick solid Blue / Green is after tuning Dotted Blue / Green is before The test car is a Auto Vios, Parts on the car: 1) Speed-d 4-1 2) HKS Hi-Power Muffler 3) Unichip Q 4) SS drop in Filter ( Stock Airbox) 5) CAI Condition of car: 1) Mobil One EO 5000Km old 2) Denso Iridium spark plug (Not New) 3) 92 Fuel ( Last minute try our best to mix with 98 Fuel) I was happy with 141bhp on crank for a Auto Vios. i expect more for MT vios. Dyno is Dynopack TCF is set at 1.2 for auto |
Looks like a gain of about 14 hp and 20 torque, yes?
I don't think a stock ECU could handle this mod, you'd have to tune the car with management like this Vios was.
would you say these cams are tunable for boost? if i got these cams and then later boosted on top of them, could i tune it also? or is the lift and dur on these cams specific to N/A tunes?
I seem to recall the early posts about Jun cams listing three different sets of specs, with this one being the most mild. My math, and memory, may be a bit fuzzy... But I come up with this as a .354 lift, that is not much more than stock.
![]() This is what is listed on the Jun website. 63 (252) 9.0 9.0 IN IN 1004M-T031 1004M-T031 JPY42,000 JPY42, 000 Can use with stock ECU Can use with stock ECU EX EX 1004M-T131 1004M-T131 JPY42,000 JPY42, 000 * * The amout of lifts shows the cam lift. * The amout of lifts shows the cam lift.
Where is the rest of the screen, RPM, AFR?
Here is the data I got when I considered stocking these:
1. 256 duration, 9.0mm lift (Street) 2. 272 duration, 9.5mm lift (NA) 3. 272 duration, 10.5mm lift (Turbo)
^woot woot^ thats what i was looking for.. and also, i do remember seeing that in another jun thread
i dont do turbo car so i am not sure. this is what i request from JUN, the 3 spec mention
1. 256 duration, 9.0mm lift (Street) 2. 272 duration, 9.5mm lift (NA) 3. 272 duration, 10.5mm lift (Turbo) also avaliable. this one i install is 264dur 9.5mm valve lift. i want a bolt-on thus i am not going for anything wild. stock lift is 9mm Stock ECU can run the cams, but advise to add tuning to max on the result. AFR i am running 13.3 for NA note i am just sharing...not selling... too far haha Last edited by Dylan Yap; 03-23-2011 at 02:42 AM. |
#15 | |
![]() ![]() Drives: toyota Join Date: Feb 2011
^ They say so, but do you want to pay $1700 to find out if you get a CEL or not?
I haven't seen an example where they just bolt on the cams, go drive the car hard, and show that the stock ECU has no problem with that. Trust me, I want it to be true as much as anyone.
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car Join Date: Oct 2008
Did you have to re do the clearances with new buckets and shims?
| JUN Releases Camshafts for the 1NZ-FE | changchewsoon | Performance Modifications | 53 | 01-23-2017 08:28 PM |
| JUN Auto Releases High Lift Camshafts for Toyota 1NZ-FE | changchewsoon | Performance Modifications | 7 | 02-16-2011 03:46 PM |
| Gude cams "NOT SO NACHO" | xbgod | Performance Modifications | 77 | 01-27-2011 01:45 PM |
| JUN Auto - 1NZ-FE I-Beam Connecting Rods | changchewsoon | Forced Induction Forum | 10 | 04-19-2010 11:00 AM |
| GI: Custom Cams | lilredrocket | Performance Modifications | 62 | 11-13-2009 10:10 AM |
