Old 05-29-2011, 01:27 PM   #1
bB2NER
My Box and Her Egg
bB2NER's Avatar
Drives: 05' Scion xB / 08' Yaris 3dr
Just got back from a 1400 mile road trip. Compared to my xB/bB with regular PS, the Yaris steering is way too touchy. It feels like you are disconnected IMHO.
bB2NER is offline   Reply With Quote
Old 05-29-2011, 10:30 PM   #2
Zebra
Zebra's Avatar
Drives: Yaris HB
Curiosity got the best of me today so I pried the 50 amp fuse out of the fuse panel and gave manual steering (aka: armstrong steering) a try. I have to admit that I was impressed with the improved handling on the highway. Keeping the Yaris going straight is full-time job with the EPS, it's much better without.
BUT...... Under 30mph it was just way too much work and in my opinion, somewhat unsafe. Manual steering in just about any other car needs less effort and yes the steering wheel is too small for manual steering. Still, it would take more than a big steering wheel to make it tolerable on a daily basis.
Having a system to attenuate the EPS at higher speeds might be the answer. I really like the effect on the highway but that's where it ends..
Zebra is offline   Reply With Quote
Old 05-30-2011, 09:42 AM   #3
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
zebra: now you know why im planning a switch option..but worried about turning this on and off while driving...
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!!
"Horsepower is how fast you hit the object. Torque is how far you move that object.."
Old 05-30-2011, 10:03 AM   #4
Zebra
Zebra's Avatar
Drives: Yaris HB
Why are you worried? Worried that a power spike would damage the EPS? Worried someone else will trip the switch and have an accident? Worried that your wiring job won't work at a critical time? Worried that an accident could result in a lawsuit for negligence?
I wouldn't worry about the power spike....
Old 08-07-2011, 04:24 PM   #5
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
I like this thread!
Marcus and CTScott.
What is the unit that adjust to speed levels...ie more power when you're not moving vs less when you're at speed? Is there any way to just affect that unit? Like telling it to give no power at all after a certain speed?
As for the switch, where in the line would you put it, between the unit and the fuse or do it in the fuse box?
Lastly...CT...I know you have ideas! Where are you at on this subject?
Old 08-08-2011, 10:27 AM   #6
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
There's a torque sensor built into the steering column that senses how much force is being applied to turn the wheels and adds more or less power to the motor to assist.
I dont know if CT has experimented with adding resistance to the output ifthe sensor to tell the system not to add as much power.
Old 08-08-2011, 12:17 PM   #7
From what I have found in my experimentation, fooling the PS ECU in regards to vehicle speed is not enough. I actually have to also override the torque sensor data. The "highway wander" is a good example of why this is necessary. Even at high speeds, there is enough power assist that small changes in the torque sensor feedback result in steering adjustment.
One of the simplest implementations may be to add a DPDT relay in line with the power steering motor leads, and control the relay based on vehicle speed.
Old 08-08-2011, 12:31 PM   #8
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Is this something that could be based on the "vehicle speed" wire on the radio harness? I've only got a basic electronics knowledge at the moment, but I'm sure there's an IC that can read the pulses from this line.
Old 08-08-2011, 12:37 PM   #9
If you wanted to do it without a microcontroller, you could use a frequency to voltage converter IC and then feed that through a comparator.
Old 08-09-2011, 03:51 PM   #10
CrankyOldMan
I've located some potential parts for these, but I'm not sure how I'd go about measuring the pulse per mph. Do you by chance already know what it is?
I'm also guessing that the signal is 12V, so you'd have to use a regulator or voltage divider to get down to the 5V input that the F/V chip is expecting. I'm still looking through the datasheet to see exactly how the F/V converter works. Any suggestions on what kind of comparator would be the right type to use?
Old 08-09-2011, 04:19 PM   #11
The VSS signal is actually a 5V signal. If memory serves me correct the frequency is 100 Hz at 40 MPH and about 20 Hz at 10 MPH.
For the comparator, a general purpose one, like the LT1011 would be fine. It is amazing how much more complicated this gets trying to do it with analog, rather than digital. I should just build you up one to experiment with using a microcontroller. I could make a simple little black box that connects to ignition switched power and then has an output to drive the relay coil. I could have a pot on the box to adjust the switch over speed.
Old 08-08-2011, 12:29 PM   #12
CrankyOldMan
If you want to just add an on/off switch that won't mess with the existing wire harness you could get an external fuse holder, 50A relay and a toggle switch. The toggle switch would be connected to the battery or accessory line and the coil of the relay, and the switch of the relay would enable/disable the power steering fuse. I'm assuming that the power steering is still 12V, so pretty much any automotive relay with 50A contact rating would work. The toggle switch can be anything that can handle 12-14V and whatever the coil current of the relay is. You would have to pull a pair of wires through the firewall, but that shouldn't be too hard either.
Old 08-10-2011, 10:18 AM   #13
rningonfumes
...it's like watching soft core.
Keep going!
Electric power steering Geoff Peace DIY / Maintenance / Service 4 04-10-2018 05:28 AM
Power Steering Fluid jstantherprsn DIY / Maintenance / Service 8 04-05-2016 06:24 PM
Power Steering Light sıɹɐʎ DIY / Maintenance / Service 12 02-19-2014 07:22 PM
URGENT Advice Needed! Relating to Power Steering, Alternator and Electrical. The Marshall General Yaris / Vitz Discussion 25 10-21-2010 08:23 PM
Can't find power steering reservoir on '10, is there one? JerseyJeff84 DIY / Maintenance / Service 4 09-07-2010 10:47 AM
