Old 08-09-2011, 03:51 PM   #29
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
If you wanted to do it without a microcontroller, you could use a frequency to voltage converter IC and then feed that through a comparator.
I've located some potential parts for these, but I'm not sure how I'd go about measuring the pulse per mph. Do you by chance already know what it is?
I'm also guessing that the signal is 12V, so you'd have to use a regulator or voltage divider to get down to the 5V input that the F/V chip is expecting. I'm still looking through the datasheet to see exactly how the F/V converter works. Any suggestions on what kind of comparator would be the right type to use?
Electric power steering Geoff Peace DIY / Maintenance / Service 4 04-10-2018 05:28 AM
Power Steering Fluid jstantherprsn DIY / Maintenance / Service 8 04-05-2016 06:24 PM
Power Steering Light sıɹɐʎ DIY / Maintenance / Service 12 02-19-2014 07:22 PM
URGENT Advice Needed! Relating to Power Steering, Alternator and Electrical. The Marshall General Yaris / Vitz Discussion 25 10-21-2010 08:23 PM
Can't find power steering reservoir on '10, is there one? JerseyJeff84 DIY / Maintenance / Service 4 09-07-2010 10:47 AM
