Old 02-21-2007, 01:29 PM   #1
Nimble
Modification Condoner.
Drives: 2007 Black Sand Liftback
Originally Posted by CASTREX View Post
The heliums are 6.5" wide.
It's weird because 205 tires should be a perfect match for this size of rim. I dunno if it has to do annything with the tires being ZR or something like that. I tought 205 will always be 205 no matter the brand or kind of tire you are using.
Please correct me if I'm wrong.
The reason is simple. Race tires like the Hankook 212's or Falken Azenis run REALLY wide. Technically yes, a 205 tire should be ok on a 7" wide wheel, but I come from the BMW camp, where you run the BEST size for that width of wheel. Examples:
8'5" wheel 245/255 max
8" wheel 235
7.5" wheel 215/225 max
7" wheel 205
6.5" wheel 195
6" wheel 185
etc etc
Problem is you have every mustang/camaro owner telling you.."Dude I run 275 Nitto's with 8" wide wheels and it's fine." And in reality his car handles like crap (Not that domestic owners care).
Tanabe DF, Debadged, stripped, Black emblems
Nimble is offline
Old 02-22-2007, 06:19 PM   #2
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
8" wheel 235
7" wheel 205
6.5" wheel 195
6" wheel 185
etc etc
Thats not 100% correct. Each tire manufacturer measures width a bit different. A 315 Nitto is as wide as a 295 BFG,Goodyear or Kumho tire. There is no real measurment standard. Your "best sizing" list is fine for certain cases, but for AWD cars, or heavier cars you will be better off going a bit wider as long as you have the correct offset and clearance.
Too narrow or too wide of a tire on a given rim is not good for handling. I would rather be on the wide side than the narrow side. The streched sidewall deal that people like right now is horrible for handling.
Ashley
largeorangefont is offline
Old 02-22-2007, 06:41 PM   #3
OK Yaris
Drives: 2007 Liftback
Just for reference, here's some photos of my Yaris with stock Bridgestones
(185/60R15) on 15" Heliums. I might go a little wider after I wear out these tires..............Mike
OK Yaris is offline
Old 02-22-2007, 08:57 PM   #4
Nimble
Those look really nice. When those wear out, you might try a 195/55 15 to get some more rubber on the road, not be too wide for 6.5" wide wheels, keep weight down, and keep gas mileage in check (by minimizing rolling resistance).
It amazes me how much "sportier" those 185/60's look when placed on a correct wheel width and a farther out offset, I'm sure it makes them stick better too, less deflection because the wheel is wider to better hold the tire in place.
Nimble is offline
Old 02-22-2007, 08:54 PM   #5
Nimble
Ashley
That's also not 100% correct. Too narrow (within reason) will almost always perform better than too wide. A 275 on a 8" wheel will deflect a lot in turns, whereas a 225, a bit too narrow won't budge in a turn.
While I see that you like to try and correct me. I have owned and raced 7 BMW's and a few were ///M cars, I understand handling and tires more than I could type in a paragraph. I used to do the rolling diameter calculations just for the heck of it with the formula memorized. Sure a 245 Kumho MX or Bridgestone S-03 will run wider than say a Dunlop SP Sport 9000 or Kumho Exsta Supra 712, but my above recommendations are damn close to spot on.
I realize you're a domestic owner at heart, and I...well...hate the damn cars, barring the Vettes, a car that can actually perform ALL AROUND well, and not be built like poo. But there's no need to argue with me on common sense things. A 245 tire will always perform better than a 265 on a 8" wheel, it fits the wheel correctly giving more precise handling. And no, I don't run euro stretched tires, just CORRECT for the wheel, that's all.
Nimble is offline
Old 02-22-2007, 09:03 PM   #6
Russelt3hPirate
l33t3st Asshole
Russelt3hPirate's Avatar
Drives: MY07 Yaris Liftback
maybe Autox is a different animal.
but I've pulled better times with my 275/40 on a 8" wheel then i did with a 245/45 on an 8.5"
same car just different wheels/tires
and the 275s were more worn.
I understand that Proper size is key to optimal handling but stating that it will "ALWAYS" perform better isn't true.
the 275 on an 8" wheel isn't ideal but when restricted to 8" for either $$ or class purposes it's better than a small tire (assuming it doesn't cause any other adverse effects of rubbing, breaking things, not heating up enough yada yada) (when talking about autox).
i refer to Autox b/c that's what I know, i'm not a road racer (yet ;) ).
Russelt3hPirate is offline
Old 02-22-2007, 09:58 PM   #7
largeorangefont
Break'em off some.
Russelt3hpirate is absolutely correct. There is no "absolute" answer here. Saying a 245 will always perform better than a 265 is just incorrect. I have seen and experienced many times that wider is generally better within acceptable limits. There is a correct range of tire for a given rim.
Your sizing list is accurate, but by no means is it the end all be all when performance is concerned. You can go wider with success if you have the ability to do so. Do you need go to the absolute limit on a Yaris for maximum performance? Probably not.
What you have owned and raced are irrelevant to this topic as are rollout calculations you have memorized. No offense, but just because you have driven a BMW around a track dosen't mean you are any good at it, or that you are some supreme source of automotive knowledge. If you are wrong, you are wrong.
Ashley
Old 02-22-2007, 11:08 PM   #8
Black Yaris
der Zeck
Black Yaris's Avatar
Let me hit some of that good shit you are smokin.
I have been doing tires since the day I turned 18, and I can state fact and back it up to disprove everything you have stated above....
let me hit that good shit one more time
BTW... I geuss you think my 225/50VR15 handle and preform like crap because they are "too wide" for the wheel and skinnier is better.... I can out corner a stock yaris all day everyday
Black Yaris is offline
Old 02-23-2007, 01:03 PM   #9
Nimble
Ashley
I felt the need to quote you to make you look like a tool, ASHLEY.
Here's what you quoted of me, but yet your second sentence sure doesn't make ANY sense when looking at what I typed. Retard.
8" wheel 235
7" wheel 205
6.5" wheel 195
6" wheel 185
etc etc
Nimble is offline
15" alloys weight? obylium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 10-25-2006 12:05 AM
Stock 15" RS 5 Spoke Rim weight? GabL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 10-03-2006 05:23 PM
Weight Savings - Removal, Reduction, Reminder.... TRD_Yaris Performance Modifications 17 08-12-2006 02:07 PM
KONIG HELIUM Ultra LIght Weight wheels C2AUTOSPL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 31 08-03-2006 06:00 AM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 07:09 PM
