Old 04-07-2011, 02:57 PM   #1
dyslexicanaboko
Drives: 2007 Toyota Yaris
So I want to share something that I learned here. Loosening the bottom bolt is not impossible, it is just a pain in the ass like a majority of us have said already. I am going to basically reiterate what was said above:
+Use the PB Lube (or equivalent) and let it work
+Use a Short 6 Point Socket or 6 Point Box Wrench (Circular Side, Not the Open Side!)
+DO NOT USE a box wrench that has more than 6 points, that will guarantee round off! I already tested this theory out twice already, ended in disaster once and the second time I caught myself before rounding the bolt (Two Different Yarises).
+Use something to gain leverage so you have more torque. My problem right now is my socket wrench is too short I need to get a breaker bar and I should be good. Some people recommend using a pipe, I think using a breaker bar would better, plus you will reuse it in the future.
dyslexicanaboko is offline   Reply With Quote
Belt Tensioner for the Yaris fmicle DIY / Maintenance / Service 25 11-26-2022 11:37 PM
yaris timing belt phenoyz General Yaris / Vitz Discussion 16 02-24-2015 01:05 AM
Seat belt buzzer is silenced billk General Yaris / Vitz Discussion 48 10-30-2013 09:58 AM
Drive belt question toyo DIY / Maintenance / Service 4 02-22-2010 07:42 PM
The Accessory belt? N9QGS DIY / Maintenance / Service 4 02-12-2009 11:05 PM
