Maybe it needs to see the transition from e-brake off to e-brake on before pressing the brake pedal?
![]() ![]() Drives: 2010 8T0 Yaris Liftback Join Date: Mar 2011
Since it needs to see it running, have you done the tach learning?
#5 | |
I'm really stumped, I tried both park brake wire grounded and the with the transition to ground. I don't know what else could be causing the system not to advance into reservation mode. |
I would check the voltages on the connectors for the remote starter to make sure your taps are goof for the e-brake, brake, tach (because it is a pulsed signal it will read as a voltage somewhere between 0 and 12 with the engine running {but should not read 0 or 12}). One of those not being good seems to be the most likely reason why it's not going in.
#7 | |
I will also test the voltages on the e-brake once connected. I know the brake connection works and the tach read (+) voltage after start. |
After a long day I got it working. Not sure what the issue was, but I was finally able to enter reservation mode and finally continue on to my power door lock conversion which went pretty smooth. Thank for the help CTScott. |
| Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 | CTScott | General Yaris / Vitz Discussion | 51 | 11-10-2012 01:32 PM |
| yaris sedan remote trunk relase question pls help soon | fantabulousbaby | New YARIS Purchase Forum | 4 | 08-05-2006 01:26 AM |
