I would check the voltages on the connectors for the remote starter to make sure your taps are goof for the e-brake, brake, tach (because it is a pulsed signal it will read as a voltage somewhere between 0 and 12 with the engine running {but should not read 0 or 12}). One of those not being good seems to be the most likely reason why it's not going in.
#2 | |
![]() ![]() Drives: 2010 8T0 Yaris Liftback Join Date: Mar 2011
I will also test the voltages on the e-brake once connected. I know the brake connection works and the tach read (+) voltage after start. |
After a long day I got it working. Not sure what the issue was, but I was finally able to enter reservation mode and finally continue on to my power door lock conversion which went pretty smooth. Thank for the help CTScott. |
#4 | |
The UltraStart units are definitely a bit more finicky to get going than others. When I installed mine I kept trying to start it before going through the config menus, and an hour later realized that there were certain parameters that had to be set before it would try to start. I would definitely install one again though. Two and a half years later, mine has been flawless.
#5 | |
But it def. is alot safer to make sure you never have any freak accidents.
#6 | |
| Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 | CTScott | General Yaris / Vitz Discussion | 51 | 11-10-2012 01:32 PM |
| yaris sedan remote trunk relase question pls help soon | fantabulousbaby | New YARIS Purchase Forum | 4 | 08-05-2006 01:26 AM |
