Old 04-09-2011, 11:26 PM   #1
Originally Posted by bad_bwoy007 View Post
Just tried that too, meaning disconnect from ground then reconnect. Still no luck.
Since it needs to see it running, have you done the tach learning?
Old 04-09-2011, 11:30 PM   #2
bad_bwoy007
bad_bwoy007's Avatar
Drives: 2010 8T0 Yaris Liftback
Let me go hook that up now.
bad_bwoy007 is offline   Reply With Quote
Old 04-09-2011, 11:50 PM   #3
bad_bwoy007
Still nothing, not able to enter into reservation mode.
I'm really stumped, I tried both park brake wire grounded and the with the transition to ground.
I don't know what else could be causing the system not to advance into reservation mode.
Old 04-10-2011, 07:44 AM   #4
I would check the voltages on the connectors for the remote starter to make sure your taps are goof for the e-brake, brake, tach (because it is a pulsed signal it will read as a voltage somewhere between 0 and 12 with the engine running {but should not read 0 or 12}). One of those not being good seems to be the most likely reason why it's not going in.
Old 04-10-2011, 08:08 AM   #5
bad_bwoy007
OK, I will actually hook up the e-brake connection, it's just hard to reach the the running relay connector to get it in.
I will also test the voltages on the e-brake once connected.
I know the brake connection works and the tach read (+) voltage after start.
Old 04-10-2011, 09:14 PM   #6
bad_bwoy007
After a long day I got it working.
Not sure what the issue was, but I was finally able to enter reservation mode and finally continue on to my power door lock conversion which went pretty smooth.
Thank for the help CTScott.
Old 04-10-2011, 09:21 PM   #7
Very good.
The UltraStart units are definitely a bit more finicky to get going than others. When I installed mine I kept trying to start it before going through the config menus, and an hour later realized that there were certain parameters that had to be set before it would try to start. I would definitely install one again though. Two and a half years later, mine has been flawless.
Old 04-11-2011, 08:33 AM   #8
bad_bwoy007
Very good.
Yea, the unit functions well and the remote I have is nice and small. Thinking about it now after the install, I could have gotten away with just install a regular automatic starter and not one specific to a manual trans because I don't park in gear.
But it def. is alot safer to make sure you never have any freak accidents.
Old 04-11-2011, 08:39 AM   #9
bad_bwoy007
Very good.
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 01:32 PM
