Used to have mpg but as its all over the place its kinda meaningless for every day use so i replaced it with speed readout.
*FIA, air intake temp AVG MPG, resets after 10 hours of down time *FWT, water temp |
![]() ![]() ![]() Drives: 2010 5 door hatch w/5 sp man. Join Date: Jan 2011
I was just playing around with my SGII adding gauges. Here are the gauges I added and the results:
FLV (Fuel Level) Is supposed to be % of tank left. Gets no reading at all so the UltraGauge makes no difference. I really would have liked that one. HPR (Instantaneous Horsepower) works. Shows about 8 HP at idle. I'll check it out when I'm actually driving to see if it gives me useful info. ![]() ERT (Engine Run Time) Shows time in minutes since you started the engine. Kind of useless. I was hoping it would show lifetime run time. AIR (Ambient Air Temp) Works well. Showed 46 degrees F and that's what it is outside. FIA (Intake-Air-Temperature) which is a standard gauge showed a much higher temp as I was not moving. PSI (Barometric Pressure) Shows pressure in PSI and I am used to inHG (inches of mercury) which is standard with barometers. Showed 14.2 PSI which is 28.91 in/Hg so you are close if you double it.
It varies constantly but my strategy is to generally try to keep MPG higher than AVG MPG.
| Autometer Phantom II gauges | cali yaris | Items for Sale by private party | 4 | 11-09-2009 07:45 PM |
| Install Oil Pressure, Voltage and Temperature Gauges with DIY Holder | bieniman | DIY / Maintenance / Service | 4 | 05-19-2009 11:40 PM |
| My new gauges set up | PETERPOOP | Cosmetic Modifications (Exterior/Interior) | 30 | 04-19-2009 08:50 PM |
| Mechanical vs Electric Gauges? | PETERPOOP | Forced Induction Forum | 13 | 04-06-2009 01:25 AM |
| WTB: Boost Gauges | Teruyume | Items for Sale by private party | 4 | 11-12-2006 02:42 PM |
