![]() ![]() Drives: Yaris sedan Join Date: Jun 2010
Hello everyone, most of you said it was leaking. Is it noticeable on the ground? What are the symptoms of a bad water pump?
![]() ![]() ![]() Drives: '09 Yaris & '10 Auris Join Date: Apr 2009
![]() ![]() ![]() Drives: '08 LB, '07 WRX Join Date: Jan 2009
![]() ![]() ![]() Drives: 2010 Prius, 2007 Yaris Sedan Join Date: Oct 2009
+1. Pink spray on the underside of you hood.
![]() Drives: 2008 Yaris Hatchback Join Date: Sep 2012
Water Pump Replaced
I have less than 75K miles and my pump bearings started to make the worst sound ever. I thought my 2008 Yaris was falling apart.
Just bought the replacement pump for about $35 and some anti-freeze for under $6. I think that's a great deal, without the warranty. If you have the warranty, be sure to use it as often as possible. |
![]() ![]() ![]() ![]() Drives: 2020 Corolla Join Date: Apr 2012
Had my water pump replaced under warranty .. not sure of the mileage when it happened.
![]() ![]() Drives: 07 Yaris 2dr hatchback Join Date: Sep 2016
I have the same colour of hatchback, I like your style. I changed my waterpump in last summer at 230,000.Also did the waterpump in my old sedan. It's a good repair to do if you want to start turning wrenches. One of the first things I learned how to do other than brakes and oil changes.
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 03:34 AM |
| Water Pump leaks and then stops | CB900F2 | DIY / Maintenance / Service | 30 | 05-09-2011 09:14 AM |
| HELP: changing water pump | dlplunkett44 | DIY / Maintenance / Service | 4 | 02-06-2011 09:26 AM |
| Water Pump being replaced... Rental Car! | slothman86 | DIY / Maintenance / Service | 12 | 08-11-2010 04:14 AM |
| Water pump belt and pulley - replaced at 36,000mi | cleong | DIY / Maintenance / Service | 3 | 03-06-2009 12:12 AM |
