Old 04-21-2011, 04:34 PM   #1
Jason@SportsCar
but the 100bhp mazda 2 makes about what with mods? and the fit?
im not sure you'd keep track of that info, however...
Only power mods in SSC/B-Spec are a drop in air filter element (in the stock air box) and a cat-back exhaust. And considering all the cars get the same mods they should all increase similarly percentage wise.
The biggest issue I see with the 2 is I don't think it can get down to a 2130lb race weight. Stock it weighs 2310lbs (data provided by Mazdaspeed). You can pull all of the interior (less the dash), AC and audio, but you have to put in a 6-point roll cage. When SCCA does the weight calculations they base it on a 180lb driver, so that would mean to hit the 2130lb number you need the car to weigh 1950lbs. Not likely in SSC/B-Spec trim.
Old 04-21-2011, 04:37 PM   #2
good point.
looks like you're driving the right car then...
Old 04-21-2011, 06:53 PM   #3
Jason@SportsCar
So when are we going to see the Micro Image B-Spec car???
Get started Garm.
2011 NYR SCCA AutoX Schedule NYR Solo Tracking, Racing, Auto-X Forum 0 04-06-2011 01:57 AM
2011 NYR SCCA AutoX Schedule NYR Solo NY / NJ/ CT / PA 0 04-06-2011 01:56 AM
SCCA Classing Update - I WAS WRONG!! ozmdd Tracking, Racing, Auto-X Forum 35 11-09-2009 10:59 AM
Benefits of SCCA rstb88 Tracking, Racing, Auto-X Forum 8 12-01-2008 02:43 PM
