Old 04-22-2011, 07:25 PM   #1
seth_man
seth_man's Avatar
Drives: 08 Liftback
Big Brake Kit Discovery
well i had some extra time at the shop and decided to try something out just for s&g's. i discovered that the AEM big brake kit for civics BOLTS ON to the yaris. NO Cutting, Drilling, Cursing or Modifying to bolt them on. 12" rotors and they fit under my 16" wheels. i did have to clearance the front top of my caliper .010" or so to have a little clearance for my stick on wheel weights.
What you will need:
1. 7mm Spacer to go between Stock Yaris caliper bracket and caliper extension bracket that comes with the brake kit
2. Longer Bolts I used 12mmx1.25mmx50mm bolts instead of the stock caliper bracket bolts
3. Nothing else
seth_man is offline   Reply With Quote
one brake light out xartrax DIY / Maintenance / Service 3 01-27-2011 12:40 PM
big brake kit turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 04-13-2007 01:44 PM
big brake kit yrsdrgn Performance Modifications 17 02-20-2007 11:05 PM
cheap trd big brake kit *joke* birdy Off-topic / Other Cars / Everything else Discussions 3 06-13-2006 12:04 AM
