advocatus diaboli
Bypass can be done with any standard 5 pin automotive relay(about 4 dollars). All you do is run 12v(86), ground(85), and parking brake sensor wire(87), then use a jumper to connect the ground to the other open pin(85&30).Tape the heck out of it and tuck the relay behind the head unit when you put it back. I just did this install with the same head unit in my Yaris about three weeks ago.
#2 | |
![]() Drives: 2006 Yaris RS 5DR White Join Date: Apr 2011
#3 | |
advocatus diaboli
I don't use the bluetooth, but my Iphone runs flawlessly...I can control my pandora through the head unit which was crucial. The touchscreen is nice, and there are a good amount of features, color options, etc. The unit fits, you just need the two plastic spacers for the sides and It looks factory when all said and done. You will need a harness, think it was something like 90's to current Toyota IIRC, but don't quote me. Install took about 40 minutes, but I take my time and heat shrink wrap all of my connections, etc...I'm kinda a stickler when it comes to wiring things. For the price(I paid 300.00 OTD from a friend, everything included) I'm very very pleased with it....I paid 3,000 for my last in dash, but that was over 10 years ago.
![]() Drives: 2011 3Dr Hatch Join Date: Apr 2011
[QUOTE=mazilla;575873]Bypass can be done with any standard 5 pin automotive relay(about 4 dollars). All you do is run 12v(86), ground(85), and parking brake sensor wire(87), then use a jumper to connect the ground to the other open pin(85&30).Tape the heck out of it and tuck the relay behind the head unit when you put it back. I just did this install with the same head unit in my Yaris about three weeks ago.
Is (86) the Amp Remote instead of Power Antenna? and if I am running a sub amp do I run the same remote wire from the relay to the amp? |
#5 | |
advocatus diaboli
[QUOTE=dzcab;576073]
