Old 04-25-2011, 04:52 PM   #5
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
Bypass can be done with any standard 5 pin automotive relay(about 4 dollars). All you do is run 12v(86), ground(85), and parking brake sensor wire(87), then use a jumper to connect the ground to the other open pin(85&30).Tape the heck out of it and tuck the relay behind the head unit when you put it back. I just did this install with the same head unit in my Yaris about three weeks ago.
-Type 07 FFL-
My odometer 03/11
