Old 04-26-2011, 10:14 AM   #1
dzcab
Drives: 2011 3Dr Hatch
[QUOTE=mazilla;575873]Bypass can be done with any standard 5 pin automotive relay(about 4 dollars). All you do is run 12v(86), ground(85), and parking brake sensor wire(87), then use a jumper to connect the ground to the other open pin(85&30).Tape the heck out of it and tuck the relay behind the head unit when you put it back. I just did this install with the same head unit in my Yaris about three weeks ago.
Is (86) the Amp Remote instead of Power Antenna? and if I am running a sub amp do I run the same remote wire from the relay to the amp?
dzcab is offline   Reply With Quote
Old 04-26-2011, 11:19 AM   #2
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
[QUOTE=dzcab;576073]
You can do that too, you just need a 12v source that powers on with the radio. I like to use a source that's not going to be utilized elsewhere, but it doesn't really matter.
-Type 07 FFL-
My odometer 03/11
